Hole in router sub base too small - Router Forums
post #1 of 3 (permalink) Old 04-04-2010, 04:27 PM Thread Starter
First Name: Robin
Default Hole in router sub base too small
Hi All,
I am using a Craftsman 1 3/4 HP Router. Up to now it has been great - I have just finished using it with the Rockler Dovetail jig I picked up recently.
Now, I am just finishing up the box I created using the dovetail jog. I went to pit the 3/8" roundover bit in the router, and where the hole is too small for the bit to fit flush for the roundover. The base does fit the brass guide bushing for the dovetail jig, so I don't want to mess with it.
Does anyone have any suggestions, or do I need to go and buy another base plate?
Thanks!
Robin.
rwalkerphl is offline
post #2 of 3 (permalink) Old 04-04-2010, 04:47 PM
kp91's Avatar
First Name: Doug
Robin,
a lot of baseplates have a recess in them for a template guide. These guides are handy, but mean the baseplate can be too small for what you need to do.
If you're working out of the table, you can make a quick and simple baseplate out of hardboard or plexi and it works great, just make the hole a big as you need. For working in the table, I have 2 baseplates, one with a 3 1/2 inch hole for big bits, one for template guides. You can make one to fit your table, or you can buy a new one.
I wouldn't recommend openning up the size of your plate, because you might want to be able to use guide bushings in the future.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 3 (permalink) Old 04-04-2010, 04:59 PM
With base plate below you use up to a 2 1/2" OD bit and your brass guides as well all with just one plate.
Amazon.com: Milescraft 1201 Base Plate / Bushing Set for Routers: Home Improvement
Originally Posted by rwalkerphl View Post
Hi All,
Thanks!
Robin.
New here lookin for advice osioradain New Member Introductions 13 02-22-2010 11:02 AM
Router plate as base plate?? xplorx4 General Routing 6 05-24-2009 06:19 PM
Replacing Router Base Weekendwoodworker General Routing 1 05-02-2008 04:55 PM
