stop router "burn" - Router Forums
post #1 of 7 (permalink) Old 04-06-2010, 07:03 PM Thread Starter
Default stop router "burn"
Hi,
I am a first time router user and first time user of this site.
What am I doing wrong when routing that causes the wood to burn.
This only happens when I router the "edge" of the wood. Against the grain.
Not when I router with the grain.(length OK....width "burns")
Thanx....
Cheaks
cheaks is offline
post #2 of 7 (permalink) Old 04-06-2010, 07:29 PM
kp91's Avatar
First Name: Doug
If your bit is dull, or you're feeding too quickly or slowly you can get burning. If you're doing an edge profile, you might try making it in multiple shallow passes, not making the bit work too hard.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 7 (permalink) Old 04-06-2010, 07:30 PM
Hi cheaks
It comes from dull bits and speed rate.. and from staying to long in one spot...
Originally Posted by cheaks View Post
Hi,
Thanx....
Cheaks
post #4 of 7 (permalink) Old 04-06-2010, 09:43 PM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. We are pleased you have chosen to join with us.
Lamentations 3:22-23
xplorx4 is offline
post #5 of 7 (permalink) Old 04-07-2010, 12:49 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hello cheaks, and welcome to the RouterForums. Nice of you to join our group.
Dave
the "Doctor"
Dr.Zook is offline
post #6 of 7 (permalink) Old 04-07-2010, 11:35 AM
dutchman 46's Avatar
First Name: Howard
Hello cheaks, Welcome to the forum! I must agree with all the others, My guess, is that the bits are new? then if You have a variable speed, the speed may be set to slow. The smaller bits use a higher speed. the larger bits go slower the speed. If You are making the cut with one pass, that can burn as well. I would almost take two passes, or three, for bigger bits, the last pass is what I call a skim cut. that one is to shave the cut to give it best quality. Thanks for joining.
John 3:16
dutchman 46 is offline
post #7 of 7 (permalink) Old 04-12-2010, 07:59 PM
Country: Japan
First Name: Benny
Perpendecular, too ?
I had a same kind of results.(correct ?)
Is bit(1/2" down cut spiral) not perpendecular to(?) a table-plate ?
A router has a many-posibility, I found step by step.
Dave san
Thank you for your avatar.
But PC890 is not suitable for it ?
Benny LaBaw is offline
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
Router table ideas Larwyn Table-mounted Routing 4 12-28-2009 01:47 AM
Router table refurb- Woodpeckers Unilift rstermer Table-mounted Routing 14 11-03-2009 12:21 PM
