Porter Cable plunge router off center - Router Forums
post #1 of 10 (permalink) Old 04-28-2010, 02:00 AM Thread Starter
Default Porter Cable plunge router off center
Any help on this issue would be GREATLY appreciated. I am using a Porter Cable router that uses the interchangeable fixed/plunge bases... the plunge base is 6931.
When I use the fixed base, everything is fine. But, when I use the plung base, the bit is off center by about .020+. If I use a 5/8 bit with a 3/4 bushing, there should be about .020- gap between the bit and the bushing... but it rubs. I turned the subbase, but it rubs in the same direction, so I know the bit is off center. I called Porter Cable's technical product helpline. The guy told me "the plunge router base isn't made to be on center when using with a bushing." Then he told me he'd send me some special 'adjustable' base to use instead.
Has anyone else had a similar situation or experience and, if so, how did you resolve it? I think this is a load of dog doo, but don't know what to do about it.
Tom Hammond is offline
post #2 of 10 (permalink) Old 04-28-2010, 07:14 AM
Hi Tom - "not made to be centered" Sounds like B*S** to me.
I haven't got the PC but if I remember my friends, the bushing relief is molded into the base. I assume you tried loosening the sub base and and adjusting it. If you can't get it that way, try removing the subbase screws and rotating the subbase around. .020 is a long way off. I'm pretty sure the 690 uses the same base as my friends and I haven't had any problem using bushings on his router.
Is this the first time you have used bushings with it?
If you can't get any satisfaction from Porter Cable, you may want to look at this guy:
Amazon.com: Milescraft 1201 Base Plate / Bushing Set for Routers: Home Improvement
Fits right on your router, centers up nicely and you don't need to fool with the lock nuts.
John Schaben
jschaben is offline
post #3 of 10 (permalink) Old 04-28-2010, 08:04 AM
First Name: del
Default Router base
i have the Milescraft 1207 Router Design Inlay Kit My 690 is right on with the centering pin that come's with this The base is the same So may be worth getting It will fit lot's of routers It may be of plastic Or some hard stuff I don't belive you will ever have any problum I use the Milescraft 1207 Router Design Inlay Kit Every day and it is still like new A easy way out I have the plung base and it is right on If you bought it from a box store take it back and get another unit Of course the plung base is sold seperate I have 2 set up One is new in the box Just don't need it Have a life time of routers and base's good luck
Amazon.com: Milescraft 1207 Router Design Inlay Kit: Home Improvement
del schisler
port st. lucie, florida
del schisler is offline
post #4 of 10 (permalink) Old 04-28-2010, 08:42 AM
scrollwolf's Avatar
First Name: Jack
Hi Tom,
John is right. What the guy from PC told you is B***S***! I have the 6931 base and I use it with both my PC 690 and my PC 9290 battery operated router. You must use a centering kit and it will allow you to use the baseplate that came with your router.
You loosen the screws on the base plate, install the centering kit, tighten the centering pin(by hand), lower the base so that the pin is captured in the bushing and then tighten the baseplate screws and the base will be centered.
Baseplate centering kit link:
Buy Base Plate Centering Kit 2 at Woodcraft.com
Jack
"If it ain't broke, don't fix it, give it to me!"
scrollwolf is offline
post #5 of 10 (permalink) Old 04-28-2010, 10:28 AM Thread Starter
Thanks guys. I thought what the guy told me was a load... and it sounds like that's the consensus.
Will pursue the centering device and will post back when I've resolved this issue. THANKS again.
post #6 of 10 (permalink) Old 04-28-2010, 05:48 PM
Ghidrah's Avatar
First Name: Ronald
One more with a PC 693 I have never had the fixed base in it and I use guides and the inlay kit often. The PC tech is lying or an idiot.
Ghidrah is offline
post #7 of 10 (permalink) Old 04-28-2010, 06:14 PM
Hi Tom
Sorry to say the guy from PC is right, if you take a hard look at the bases you will see why he said that .the standard base has split in the case and the plunge router base must have the room to get the motor in free and easy and slide by the motor line up pins..
But he didn't go the extra mile and tell you how to fix the problem ..
But the Milescraft base plates takes that error out in a heart beat plus it will let you use 1 3/4" OD bits without taking off the base plate and many of the profile bits are that big..
post #8 of 10 (permalink) Old 04-29-2010, 07:20 AM Thread Starter
Thanks for the additional info. What about a standard ol' plunge router... not the interchangeable base one? Would that be better? I'm using this to make mortises, and need it to be accurate. Being this far out makes it extremely difficult to make a good fit at the accuracy I want.
post #9 of 10 (permalink) Old 04-29-2010, 08:05 AM
First Name: del
one other thing when putting the motor in the base Don't let go all the way down Bring it un 1/4" so that when you tighten the allen bolt to hold base to the motor If you need to take it out You just losen the allen bolt it will come loose But if it is all the way to the bottom Their is no place for the motor to slide down and loosen You will have to take the bolt out to get to loosen up
del schisler
post #10 of 10 (permalink) Old 04-29-2010, 08:46 PM
First Name: Joe
Scroll Wood's solution is correct up until he said to retighten the baseplate screws. I have the same router and had the same problem. Porter Cable in their infinite wisdom put tapered holes in the baseplate, so guess what? When you retighten them with the factory screws, the baseplate goes right back to being misaligned.
What I did was to take a 5/16 brad point bit and very carefully counterbore the baseplate screw holes. Then go down to your local hardware store and buy panhead (aka binderhead) head screws (they are metric) to replace the tapered screws used by PC. That way when you center the baseplate using the centering tool, it won't shift when you retighten the baseplate.
I used the fastest speed available on my drill press and used a hit and release method so as to not get the phenolic base plate too hot.
ajosephg is offline
dust hookup for Porter Cable 6931 plunge base? z399y Portable Routing 16 08-25-2010 06:53 AM
Porter Cable T+G router bit,$12.99 shipped Tommyt654 The Bargain Bin 2 04-24-2010 02:34 PM
Bosch 1617vs Verses 690 Porter cable Glenmore Tool Reviews 20 08-09-2009 09:36 PM
porter cable router bits delroy33 Tools and Woodworking 1 10-14-2004 05:37 PM
