1/4" vs. 1/2" bits - Router Forums
post #1 of 19 (permalink) Old 05-01-2010, 09:12 PM Thread Starter
Default 1/4" vs. 1/2" bits
Can anyone explain the difference between using a half inch or quarter inch bit?
Half inch is stronger, quarter inch has less mass???? What gives.
Assume both bit tips are exactly the same size
BBK.2008 is offline
post #2 of 19 (permalink) Old 05-01-2010, 09:30 PM
The 1/2" shanks are stronger & provide less vibration than the 1/4" shanked bits. They each have their place. For me if same profile cutter is available in both shank sizes I will get the 1/2". The smaller profiles usually have 1/4" shanks. A good collection of bits will have both.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 19 (permalink) Old 05-01-2010, 11:35 PM
First Name: Mal
Generally speaking, bigger is better for rigidity but as usual there will be exceptions. Some that come to mind are:
Small bits, say 1/8th inch plunge bit, will always have the weakest and most flexible portion at the smallest diameter, so there is no real value in going to a 1/2in shank version unless your machine can only handle 1/2in bits.
When using template guides bushes, the shank or cutter generally has to pass through the guide bush. Often not an issue, but with Leigh jigs and bushes it normally limits the user to 8mm (3/8in) or 1/4 in shanks for standard bits and bushes.
Again it's horses for courses.
malb is offline
post #4 of 19 (permalink) Old 05-02-2010, 12:51 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hello BBK. Welcome to the RouterForums. A great forum to be a member of.
Dave
the "Doctor"
Dr.Zook is offline
post #5 of 19 (permalink) Old 05-02-2010, 02:26 AM
BigJimAK's Avatar
BBK,
Occasionally the 1/4" shanks can come in handy too. I wanted to make a 3/8" deep, 1/2" wide cut in 2" MDF, following around a template made of 3/4" MDF. Using a 1/4" shaft, 1/2" dia, 1/2" cutting length hinge mortising bit with a 1/4" ID x 1/2" OD bearing on the shaft (with bearing retainer) I was able to have the bearing riding against the template before starting the router and plunging to depth.
BigJimAK is offline
post #6 of 19 (permalink) Old 05-02-2010, 04:50 AM
RustyW's Avatar
First Name: Rusty
Don't put all your eggs in one basket. I was buying all 1/2" shank bits for the same reasons. Then I bought a Bosch Colt and only had a couple 1/4" shank bits. But it was a good excuse to buy more.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
post #7 of 19 (permalink) Old 05-02-2010, 08:01 AM
Hi BBK
For me it's having the right tool for the job, it's like having 1/4",3/8",/1/2",/3/4" drive sockets sets no one tool can do all the jobs..
post #8 of 19 (permalink) Old 05-02-2010, 01:58 PM
BigJimAK's Avatar
Hi BBK
BJ.. For me, I use the 1/2", 3/8" & 1/2" sockets. For anything requiring a 3/4", I let my mechanic do it! Your point is well taken, however!
BigJimAK is offline
post #9 of 19 (permalink) Old 05-02-2010, 02:21 PM
Hi Jim
Sometimes it takes the 1" drive sockets that's when I get the 1" inpact out (the tank) you just never know sometimes what it will take to get that sucker off..but I do cheat sometimes when the bolts are rusty and get the tank out to just snap the bolts off sure saves a lot of time..can't do that with 1/4" drive sockets but I have in the pass had to use the 4 to 1 multiplier to break the big ones off...right tool for the right job thing ..just like router bits..
post #10 of 19 (permalink) Old 05-02-2010, 05:56 PM
Hamlin's Avatar
First Name: Ken
Hi Jim
I've used those 1" "heavy tanks" before. Fun when they break lose what you're working on. Not so fun when they don't. Sometimes, those tractor trailer lug nuts DON'T break free when needed. Fun to hear them "hammer" though.
Ken
"A VETERAN"
Hamlin is offline
Using 1/2" shank bits in 1/4" routers? baronr Router Bits - Types and Usage 14 12-28-2013 10:58 PM
Why the difference in 1/4" spiral upcut bits? Skyglider Router Bits - Types and Usage 7 12-14-2008 05:41 PM
1/4" shaft bits g-man Starting Off 2 01-03-2006 04:14 PM
1/2" collet with 1/4" bits normcatalunya General Routing 2 08-19-2005 06:04 PM
