Craftsman Router 1 1/2 hp model 315.17491 - Router Forums
post #1 of 5 (permalink) Old 05-10-2010, 10:12 AM Thread Starter
Default Craftsman Router 1 1/2 hp model 315.17491
I have a Craftsman Router 1 1/2 hp model 315.17491. It had worked fine for quite some time then it quit. No response when switch was pressed. I took it apart and I think the switch is bad. The book showed 623814-004 as the switch part number but Sears provides 998895-001 as the replacement. My first question is how to wire the new switch. It comes with no instruction. The old switch was wired as follows: (View looking down with button on right)
Upper left corner: Red wire going to motor
Lower left corner: Red wire going to lamp
Upper right corner: Black wire going to power cord (through switch cord)
Middle right position: White wire going to black motor wire
Lower right corner: Red wire going to lamp
The new switch has different arrangement for wiring.
Left center one hole marked with #1
Mid-location two holes (an upper and a lower) marked with 1a
Right two holes (an upper and a lower) marked with 2a
Has anyone encountered this problem? Can anyone provide information on which wire goes where on new switch?
As far as the wiring connection to the motor, I believe, but am not certain they are as follows:
Switch Cord Red to Motor Red
Power Cord Black to Switch Cord Black
Power Cord White to Motor White
Switch Cord White to Motor Black
Can anyone confirm these connections?
John Shearer
[email protected]
post #2 of 5 (permalink) Old 05-10-2010, 06:27 PM
BrianS's Avatar
First Name: Brian
Check here switch wiring It might provide you with the information you need.
Brian
(Origin uncertain)
BrianS is offline
post #3 of 5 (permalink) Old 05-12-2010, 03:47 AM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. We are pleased to have you join us.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 5 (permalink) Old 05-12-2010, 11:30 AM
RJM60's Avatar
First Name: Robert
The new switch is a direct replacement for the original. Sears does this all the time. The new switch should wire up the same way as the original. If the connectors are in different places, look for identification letters on the switch bodies and connect the wires to the same connector number.
RJM60 is offline
post #5 of 5 (permalink) Old 05-13-2010, 12:27 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hello John. Welcome to the RouterForums. Hope you become an active member of this great forum.
Dave
the "Doctor"
Dr.Zook is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Craftsman 2hp professional router table combo... Duane867 Table-mounted Routing 2 01-03-2010 11:12 PM
craftsman router crafter model 92525 bubba1118 General Routing 2 10-26-2009 12:32 AM
