Help me go shopping, or slow me down - Router Forums
post #1 of 14 (permalink) Old 05-11-2010, 07:23 PM Thread Starter
First Name: Bob
Default Help me go shopping, or slow me down
Good Evening
I am a newbe and have never used a router before, but I've been reading a lot of stuff. I need some cabinets for the garage and want to do raised pannels to match a set already out there. It will cost about $1,500 to have them made, which is only $400 more than the store, which doesn't even cary the tall uppers. I thought I could buy a buch of tools for the same money and make the cabinets. I was thinking about the DEWALT 2.25-HP Fixed Base / Plunge Router Combo Kit (Lowes $200) and a router system from Kreg, Woodpecker or Bench Dog. Sears has the complete Woodpecker system for $799 online and catalog.
Am I jumping into this to fast to go spend $1,000+ to get started?
If not, which system is best. I noticed some posting on Kreg and they are buying the Woodpecker lift for their tables; why not go all the way Woodpecker. Bench Dog doesn't look as fancy, but I like the cast Iron.
What bits are best? Looks like they should be 1/2", but what brand for raised pannels.
Anyway you get the drift. Should I have the cabinets made and learn about routing with just a hand held, or get a system too? Which one?
Thanks, I hope you like shopping with me-lets go!
Bob
rstenevik is offline
post #2 of 14 (permalink) Old 05-11-2010, 07:26 PM Thread Starter
First Name: Bob
I Forgot to ask what router should I get for the table?
Bob
post #3 of 14 (permalink) Old 05-11-2010, 08:56 PM
Hi Bob
" Am I jumping into this to fast to go spend tons of money"
Yes ,,if you are gearing up just to make some cabinet with raised panels, I would suggest you look around for some ready made ones that you can pickup for peanuts, you can find many type of the takes outs, in Denver last year they had a truck load sale, all cabinets with doors for 15.oo ea.. I'm sure you can find a outlet in your town that have many..for sale that way..
The doors makes the cabinets, you can buy doors all over the place cheap here's just one place ..
http://shop.ebay.com/?_from=R40&_trk...All-Categories
http://shop.ebay.com/cabinet_door_ma...&_trksid=p4340
Originally Posted by rstenevik View Post
Good Evening
Bob
post #4 of 14 (permalink) Old 05-11-2010, 09:02 PM
Gene Howe's Avatar
First Name: Gene
I'm sure you will get many, many opinions about the table, lift and router.
My favorite is a 3.25 hp Porter cable motor in a Jessem Smart lift turning a raised panel set, which included the coping bits for the rails, from CMT. The table and fence is from Jointech.
There are far less expensive options, though.
Study all your options well. Cheap is not always best (seldom, actually) but, there's no reason to over buy, either.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #5 of 14 (permalink) Old 05-11-2010, 09:15 PM
MikeMa's Avatar
This is how I got started with my own router table. I remodelled my bathroom and decided to do my own raised panels doors (which eventually did turn out!) First, it is worthwhile to slow down just a bit, even if that means having a cabinet without doors for a little longer (the bathroom went a year). ;-)
First, for a router, you are going to get a lot of different brand and model recommendations. (I personally have the Bosch 1617 combo kit) When I go tool shopping, I drive the sales guys nuts, because I will 'play' with it is best I can without actually plugging it in and turning it on. Do this with the various routers to determine which has the best feel for you. For what you are doing, you will need at least a 2HP router with a 1/2inch collet. This is going to run around $200 in the box stores. If you are going to be doing a lot of raised panels, you may want to consider a 3HP router. This will cost you over $300. I have done some raised panels on my 2.25 HP router at low speed and it is sufficient for what I have done.
Now for the table, I personally built mine, and has done me very well. I built mine for right around $100, the most expensive part being the plate and extra fixed base. (I actually was lucky enough to find one a custom made plate with base already installed on ebay) With the raised panel doors, you will want a table that has a big enough surface to safely run you doors across. When it comes to tables, whether you buy or build, do your homework to make a determination as to what works best for you.
MikeMa is offline
post #6 of 14 (permalink) Old 05-11-2010, 09:53 PM
iamwelty2's Avatar
First Name: Terry
Gee Bob, kinda depends... If you're going to just do this project then I would have them made... to much cash if it's a short term situation. Also, what other tools do you have? You'll need a table saw, sanders, a jointer (will make life much easier), clamps, router bits. One thing I would check into is an adult education wood working class. High Schools, Junior Colleges frequently have them and for a pretty cheap fee, you can use their equipment and have some input from an instructor on what you're trying to do.
However, if your going to buy... I'd look at the Triton 3 1/4 hp router, it has an above table crank so you don't need a lift. Currently on sale at Woodcraft for $269 with free shipping, Incra has the best plate and I think they are on sale at Incremental Tools... it's a 3/8" alumimum plate.
iamwelty2 is offline
post #7 of 14 (permalink) Old 05-12-2010, 06:30 PM Thread Starter
First Name: Bob
Thanks everyone
I do have the other shop equipment (15 year old craftsman table saw, jointer, drill press, lathe and band saw that I picked up for $275 total. I am rebuilding/refreshing them now and the parts have cost me about $125. I am wondering how to do the panels after they are glued up and dry. All I have are hand held sanders. I want to retire in two years, so am trying to build the shop. I also have a new 12" Milwaukee sliding miter saw I bought to do the base board in the house during the remodel; boy, is it nice!
I am leaning towards the cast iron Bench Dog table and prolift PL1002 with the PC 7518 router. Can you buy the motor all by itself?
Thanks again for your inputs.
Bob
post #8 of 14 (permalink) Old 05-12-2010, 06:42 PM
TwoSkies57's Avatar
Bob..
I'll play the smarta$$ here and just flat out ask ya...
do you have any wood working skills? Experience? background?
You've no doubt have plenty of ambition which is a very good thing *S*
If you do.. then you know what your getting into and what it'll take to accomplish what your looking to do. You're money will be well spent..
If you don't. maybe consider treading softly into the hobby first. See if you like it, have skills for it. If you do, great, proceed,,, if you dont'... then you're not out a small fortune..
bout the only thing I can offer you on the Bench dog rig is that I've seen it reviewed well often. the down size is that I do believe you are limited to bench dog lift/router plates because of their "odd" size opening in the router table.
The PC 7518 is the industry benchmark for large routers. I've a big Milwaukee and have absolutely no complaints! you can buy the PC motor only easily. Shop around, you'll be able to save anywhere from 50 to 75 bucks on the motor only option.
TwoSkies57 is offline
post #9 of 14 (permalink) Old 05-12-2010, 07:10 PM
Gene Howe's Avatar
First Name: Gene
[QUOTE=rstenevik;185670]Thanks everyone
Yes! To both, and you won't be sorry. You'll love them both. Oh yeah, sure you can buy the 7518 motor alone. Some might, but I couldn't handle that monster as a hand held router. It's a beast! But, oh so nice.
Gene Howe
Snowflake, AZ
post #10 of 14 (permalink) Old 05-12-2010, 08:36 PM
BigJimAK's Avatar
The part number for the 7518 motor-only is a 75182, which can be Googled.
BigJimAK is offline
Shopping: 3 HP & up routers ? which one? Bogydave General Routing 12 01-31-2009 05:53 PM
Shopping: hazardous to my wallet Amy Wood Scrolling 0 12-25-2008 09:44 AM
Slow Site Roefa Lobby 5 10-12-2007 09:52 AM
Forum Really Slow... challagan Site Help and Suggestions 8 08-26-2007 04:35 PM
On Line Shopping reible The Bargain Bin 8 08-28-2005 09:33 PM
