Craftsman router won't start - Router Forums
 1Likes
post #1 of 13 (permalink) Old 05-19-2010, 01:52 PM Thread Starter
First Name: N/a Bill
Question Craftsman router won't start
I have just joined Router Forums. I live in Austin, Texas, and am an avid mid-level woodworker, but not a big router user. Today my Craftsman 130.26620 "Professional" router went on the blink, which is why I'm here. I've been using it in a router table with a dedicated on/off switch, thus leaving the router always "on." Today I took it out to use it in the plunge base and it won't turn on at all. Is there a reset button? (I cannot find such.) Is the switch replaceable? Any help will be appreciated.
wwkibler is offline
post #2 of 13 (permalink) Old 05-19-2010, 11:11 PM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. We are pleased to have you join us.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 13 (permalink) Old 05-20-2010, 12:43 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hello Bill. Welcome to the RouterForums. Thanks for becoming a member of our community.
Dave
the "Doctor"
Dr.Zook is offline
post #4 of 13 (permalink) Old 05-20-2010, 12:45 AM
Hi Bill
If you had it upside down all this time with the switch on and when you use it right side up the router dust may have got into the switch, I would suggest you blow it out real good, but yes you can get a switch for it but it sounds like a good cleaning out may do the trick..
post #5 of 13 (permalink) Old 06-08-2010, 01:48 PM
Hey Bill,
I have the same router with the same issue. I posted a couple weeks ago and was advised to replace the switch which I just did 15 minutes ago. It fixed the problem. I had also replaced the brushes but it didn't fix the issue. The switch is only a couple $$, available through Craftsman or Bosch (they manufacture the same router under a different model #) and a snap to replace once you take off the top cover. I'll never leave my router upside down now for an extended time.
Best of luck
Woodmills_74 is offline
post #6 of 13 (permalink) Old 06-14-2010, 12:25 PM Thread Starter
Smile Craftsman router won't start
Dear Woodmills,
Even cheaper than replacing the switch is taking it out and cleaning it. Seems that very fine sawdust accumulates in it and can easily be blown out once you've removed the switch and taken off its plastic back. Thanks for the reply!
Bill
wwkibler is offline
post #7 of 13 (permalink) Old 08-23-2011, 09:41 PM
Country: Argentina
First Name: Carlos
I have a 17543 Craftsman Router.
I´d used for a couple of days on a Router Table and worked fine till today, it just stop.
The power is fine, Brushes look good, lights are on but won´t start. Any suggestion ?
Thanking you for youre Time
Carlos
carlosworkshop is offline
post #8 of 13 (permalink) Old 08-23-2011, 09:49 PM
Hi Carlos and Bill
They are not to be used all the time upside down, blow out the switch good, take the switch out if you need to and blow it out..
post #9 of 13 (permalink) Old 08-23-2011, 09:56 PM
All routers used in a table need to have the dust blown out of them on a regular basis. If you don't have an air compressor you can use a can of Dust off which is sold for cleaning computers. I blow mine out an a regular basis and have never had problems with either of my two 1617's.
Bill, I know Bosch replaces defective switches once at no charge. Your Craftsman model26620 would fall into the right time frame and may be covered by the same warranty action. It is worth a phone call to Sears and then a Bosch service center about it. If you have to replace the switch I suggest buying it from Bosch for the warranty. Bosch goes beyond the written warranty most of the time to make sure customers are happy.
post #10 of 13 (permalink) Old 08-23-2011, 09:57 PM
Carlos, it sounds like the speed controller unit has failed. It is easy to change this part. If you are comfortable working on the motor just bypass the speed control and see if it works. If not take it in for service.
Newbie: Need help changing bit on older Craftsman Router coolguy982 Router Bits - Types and Usage 11 02-28-2010 03:21 AM
Craftsman Router with Wolfcraft® Folding Router Table WoodCrazy Table-mounted Routing 2 01-05-2010 01:12 AM
Craftsman Router Not Working Properly cosmokramer General Routing 13 10-15-2009 06:28 AM
Craftsman Router Lathe Doyle Jigs and Fixtures 16 06-30-2008 12:25 AM
