Bosch router 1617/18 EVS won't start - Router Forums
post #1 of 4 (permalink) Old 05-30-2010, 06:42 PM Thread Starter
Frank G's Avatar
First Name: Frank
Default Bosch router 1617/18 EVS won't start
Worked fine when last used (several months ago)
Outlet is hot.
Is the plastic cartridge on the power cord marked "do not open" a fuse. Dare I open it?
Anyone know a good repair shop near Great Falls, Va?
Thanks, Frank
Frank G is offline
post #2 of 4 (permalink) Old 05-30-2010, 07:20 PM
Outlet is hot.
Thanks, Frank
Hi Frank, can you turn the thing freely by hand with it unplugged? Thing that bothers me is you said the "outlet is hot". Otherwise I would guess the switch. Might be the switch anyway, was a lot of discussion about the switches on those awhile back, maybe someone who has torn one apart will jump in here.
John Schaben
jschaben is offline
post #3 of 4 (permalink) Old 05-30-2010, 10:57 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hello Frank and let me welcome you to the RouterForums. Glad to have you join us.
John, I think Frank means the outlet is live, not hot to the touch. Hopefully.
Dave
the "Doctor"
Dr.Zook is offline
post #4 of 4 (permalink) Old 05-31-2010, 07:27 AM Thread Starter
Frank G's Avatar
First Name: Frank
John and Dave;
Thanks for quick reply. Yes, I meant the circuit is alive. and the shaft turns freely by hand. I DID unplug to turn the shaft!!!
I do suspect the rocker ON/OFF switch.
I hate to disassemble tools (right now I have a chain saw in pieces and an old Mccullough string trimmer that won't start--repair shops say "better buy a new one-- I charge too much!"); But I may take a look today at the router.
Thank you both. Frank
Frank G is offline
Bosch Router Table Plate Pattern Rhino Starting Off 8 07-16-2015 11:37 PM
Bosch router table. Wood Doc Table-mounted Routing 0 05-18-2010 08:35 AM
Bosch RA 1180 Router Table & Skil Router sjrhynard Starting Off 4 01-15-2010 05:10 PM
Bosch Router Table larryc Table-mounted Routing 1 07-06-2008 12:31 PM
