Cutting a little at a time - Router Forums
post #1 of 13 (permalink) Old 05-31-2010, 10:49 PM Thread Starter
Default Cutting a little at a time
Hi,
I've seen a bit of information around, and read information, on not cutting too much at one time.
This makes a lot of sense to me, but something I've not come across has been regarding how to go about doing this with a table mounted router.
I understand the concept of taking off small amounts until you achieve the actual edge/depth you want, but I have one question remaining.
For this example specifically, I am using a bit used to make a simple rounded corner.
When slowly incrementing the cuts to avoid trying to take to much material at once, do you slowly raise the router with each pass, or do you move the fence? Or both?
Any particular reason as to why?
Thanks.
Neural is offline
post #2 of 13 (permalink) Old 05-31-2010, 11:36 PM
What size roundover are you using? Most can be done in one single pass no problem.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 13 (permalink) Old 05-31-2010, 11:44 PM Thread Starter
It is a 1/2" rounding bit, but I'm using it on 1/2" plywood (I'm guessing this is sacrilegious, but it's all I have to work with )
Neural is offline
post #4 of 13 (permalink) Old 06-01-2010, 12:06 AM
Originally Posted by Neural View Post
Hi,
Thanks.
Hi - Welcome to the forum
Most cases it can likely be done either way. Where possible, I like changing the bit height. For me and my setup that's a bit easier. Some bits however, require it be done one way or the other depending on the profile.
Hope this helps
John Schaben
jschaben is offline
post #5 of 13 (permalink) Old 06-01-2010, 02:22 PM
BigJimAK's Avatar
The neat thing about routing (and this forum) is there's often several ways to accomplish the same thing.
I prefer to get the bit height set just the way I want it (on scrap) and then move the fence until it bottoms on the bearing. My thinking is/was that if I damage a piece I can readily duplicate the cut, up until I swap bits. I've been lucky enough so far not to need it though, so its shown me no value. YMMV!!
BigJimAK is offline
post #6 of 13 (permalink) Old 06-01-2010, 04:29 PM
First Name: Mischa
Indeed. There is yet another way that avoids moving the fence or the router height altogether. Say you want to approach the final cut by adjusting the height. First set the bit height to the final value. Then put two sheets of 1/4" or whatever hardboard on your table with holes where the router bit is. Make your first cut, remove one sheet, make another cut, remove the second sheet, make the final cut. Similar approaches can be taken with the fence distance as the adjustable variable.
I think the benefit of this approach is that you don't have to mess with painstakingly adjusted fences or bit heights.
Best - MM
xvimbi is offline
post #7 of 13 (permalink) Old 06-01-2010, 06:11 PM
With a 1/2" roundover & 1/2" plywood you will have to rely on your router fence to guide the material as it would completely miss the bearing if your bit has one. I feel you can run this in 1 pass. A 1/2" roundover is not that much material to remove. If your bit has a bearing you can set the fence flush with the bearing & a straight edge.
The height will have the bottom edge of the roundover flush with the table top. If it makes you more comfortable you can do 2 passes. Just move the fence forward towards you to recess the bit a little behind the fence. Then you can use a straight edge to flush the final cut.
Whittier, CA.
jlord is offline
post #8 of 13 (permalink) Old 06-02-2010, 04:20 PM
First Name: Kirk
I would suggest that you use a smaller bit. 1/2 in on1/2 ply is a little large and you won't get much of a roundover I think you will be much happier with a 3/8 or a1/4 bit.
ZABOI
ZABOI is offline
post #9 of 13 (permalink) Old 06-02-2010, 04:31 PM Thread Starter
Well, part of what lead me to this forum is the issues I ran into with making one pass.
The amount of material it is removing *appears* to not be very much, but on a test piece of plywood, going for one pass.. well.. it smelled interesting.
I ended up, for the pieces I needed, making about 4 passes on each, after each pass, I adjusted the fence about 1/8th inch.
It came out acceptable for what I needed. Again, for me, I do what I call "Caveman Carpentry". The objective is strength and functionality, and not necessarily good looking or efficient, but I do want to learn how to use the router for things like rounded corners and smoothing edges out. I'm also interested in learning how to do dovetail work.
By the way, thanks everyone for the help and advice.
Neural is offline
post #10 of 13 (permalink) Old 06-04-2010, 07:13 PM
First Name: del
in a table mounted router and bit with a beiring on the top use a fence and use a brass bar or a large bit and move the fence over to where the beiring just rub's now that if the most cut that you can get But now when you rase the bit up you will get more profile and the round over will leve the little grove in the round over But the cut is all that you will get Now what you can do is not let the beiring get to the brass bar of bit so that it doesn't rub Now you will get less of a cut Now move it over and do another cut do this tell you get the brass bar or bit that rubs on the beiring This is the max of cut Hope this helps's been doing routers for yrs and table mounted and plung also have 5 routers and 3 router table's del
del schisler
port st. lucie, florida
del schisler is offline
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
Long time listener, first time caller wood-hedge New Member Introductions 2 07-14-2009 06:46 PM
Proper bit for plunge cutting? ekesz13 Router Bits - Types and Usage 21 01-11-2009 10:12 PM
Cutting frame members at 45į simplenik Tools and Woodworking 11 05-31-2007 09:03 AM
