Craftsman Router model-315175170 - Router Forums
post #1 of 3 (permalink) Old 06-09-2010, 12:02 PM Thread Starter
First Name: Kent
Default Craftsman Router model-315175170
Hi, I'm Kent - and I'm really new to using routers... I was given a variable speed router as a gift, and I'm wondering about mounting it in a table. Would this be a good application for this router? And if so, what speed setting should I use?
Thanks!
mooneykb is offline
post #2 of 3 (permalink) Old 06-09-2010, 04:55 PM
RJM60's Avatar
First Name: Robert
Thanks!
For most bits, use it at full speed. You only need to think about reducing the speed when you start using cutters over 1-1/4" (or so) diameter, like the large panel raising bits.
Why not use it as a handheld first. There are some good threads about template projects that would ideal for this router. If you have a specific project in mind, you could then decide if you need to mount it in a table, or not.
To answer your question, yes, you could mount this router in a table.
RJM60 is offline
post #3 of 3 (permalink) Old 06-10-2010, 02:15 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Kent. Glad to have you join us.
Dave
the "Doctor"
Dr.Zook is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Craftsman Router Model 315.17381 Owner's Manual EileenSteiner General Routing 7 05-11-2010 12:03 AM
Craftsman 2hp professional router table combo... Duane867 Table-mounted Routing 2 01-03-2010 11:12 PM
