Paper Masking on Polycarbonate - Router Forums
post #1 of 18 (permalink) Old 06-11-2010, 10:25 AM Thread Starter
First Name: tim
Default Paper Masking on Polycarbonate
Does anyone know how to continually router parts without leaving any frays from the paper masking? It seems especially on a specific type of PC its called ar-1 and my customer can't have any frays on the paper side. I can achieve this on the first say 5 runs but after that it seems the material wants to fray instead of cut. I have tried almost every tool that Onsrud makes at every speed, I have tried leaving .01-.05" left for just a finish tool with the same results. I'm just looking for something that is consistent with no frays. Thanks
thuston is offline
post #2 of 18 (permalink) Old 06-11-2010, 12:41 PM
AxlMyk's Avatar
It might be the bit getting hot. Is it collecting bits of plastic on the blades?
AxlMyk is offline
post #3 of 18 (permalink) Old 06-11-2010, 02:43 PM
scrollwolf's Avatar
First Name: Jack
Thuston,
When I cut it with my miter saw or table saw, I sandwich the poly between two pieces of 1/8" plywood or masonite. It helps to prevent over heating.
I don't know if that will work in your case.
Jack
"If it ain't broke, don't fix it, give it to me!"
scrollwolf is offline
post #4 of 18 (permalink) Old 06-12-2010, 12:58 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Tim. Glad to have you as a new member of our community.
Dave
the "Doctor"
Dr.Zook is offline
post #5 of 18 (permalink) Old 06-12-2010, 01:54 AM
dermer2002's Avatar
First Name: Max
Hi Mike,
Could you post a picture or two? Are you using a straight bit? Have you tried a down spiral bit?
Max
Pacific Northwest
Begin at the beginning and go on till you come to the end; then stop. ~Lewis Carrol, Alice in Wonderland
One day, someone showed me a glass of water that was half full. And he said, "Is it half full or half empty?" So I drank the water. No more problem.
The capacity to learn is a gift;
The ability to learn is a skill;
The WILLINGNESS to learn is a choice.
dermer2002 is offline
post #6 of 18 (permalink) Old 06-12-2010, 08:12 AM
TWheels's Avatar
Tim, Welcome to the forum. I am sure you find many friendly people with all levels of experience, and many willing to share.
As Mike and Scrollwolf have suggested, I too thought heat. I think specifically the problem is the bit itself. Would it be possible to change bits after every 5 cuts? You have not given many details, but if 5 cuts is one workpiece, change bits for each work piece. It will add to the time, but it will reduce the fraying of the paper backing.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #7 of 18 (permalink) Old 06-12-2010, 08:17 AM
TwoSkies57's Avatar
Would scoring along the cut line with an xcto knife or scalpel prior to routing be practical?
TwoSkies57 is offline
post #8 of 18 (permalink) Old 06-12-2010, 08:42 AM
Hi Tim - Welcome to the forum
ar-1 seems to be an abrasion resistant stuff, also trade name makrolon. Just got a hunk of this stuff in for some jigs I have planned but haven't had a chance to route any yet.
The fact that you can make about 5 cuts before the issue arrises indicates to me, and others apparently, a temperature problem. I think we will need some more specific information. Configuration of the bit; spiral, straight, straight shear, O-flute, HSS or carbide? Thickness of the stock? Bit speed?
Overall, I have been somewhat under impressed with Onsrud bits overall but that is just me.
Let us know
John Schaben
jschaben is offline
post #9 of 18 (permalink) Old 06-12-2010, 09:09 AM
TwoSkies57's Avatar
having done a google search ("routing makrolon", thanks John for a trade name!)... scoring probably would not be a practical method.
Routers with a speed of 20,000 to
25,000 rpm are preferred. Use straight (fluted 2 or 3)
carbide-tipped or high-speed steel router bits. Bits should
be 1/4˝ to 1/2˝ diameter for best results. Use a router with
at least 1 H.P. motor.
From: http://www.curbellplastics.com/techn...e-makrolon.pdf
there appears to be a number of different means to shape this stuff....Bit selection appears to be the most critical factor..
Use of a "longer" bit that would allow you to raise or lower the bit (relative to the contact area on the ar-1) may give you more usefull life out of the bit.
post #10 of 18 (permalink) Old 06-12-2010, 09:35 AM
Hi Bill - hmmm, that's interesting. I've always slowed the speed down for plastics. Like I said in my last post, I haven't routed any of this stuff yet but i may just take a shot at top speed. I did order in a 1/4" Amana O-flute to use on it and it has a mfg speed limit of 35,000.
John Schaben
jschaben is offline
Specialty Burn Through Paper ? williamyoung Pyrography and Carving 9 12-21-2009 03:51 PM
Why Graphite Transfer Paper ? williamyoung Pyrography and Carving 4 12-04-2009 08:11 PM
Graphite paper for tracing ? williamyoung Pyrography and Carving 8 12-01-2009 01:00 PM
Micro fiber or micro-mesh paper...? anotherBob The Finishing Touch 0 11-05-2009 10:23 PM
