Plunge base for craftsman router - Router Forums
post #1 of 6 (permalink) Old 06-11-2010, 04:11 PM Thread Starter
First Name: alex
Default Plunge base for craftsman router
Hello,
I have had a craftman 17543 router for about 2 years, and the plunge base is messing up. I use it to mainly cut holes in 3/4" wood. I usually make 3 or 4 passes around, and by the time i get finished the plunge base shifts on me, almost every time, causing a lip in the hole. I have tried messing with the base several times, but never works perfect now. Does craftsman make a better plunge base for this router? or will another brands base fit it?
Thanks,
Alex
farriswheel is offline
post #2 of 6 (permalink) Old 06-11-2010, 06:09 PM
Hamlin's Avatar
First Name: Ken
Originally Posted by farriswheel View Post
Hello,
Thanks,
Alex
I suggest you do some searching for Bobj3's posts/threads. I believe he's posted several times the solution to this problem.
Ken
"A VETERAN"
Hamlin is offline
post #3 of 6 (permalink) Old 06-11-2010, 09:44 PM
BigJimAK's Avatar
Search for BobJ3's threads, Ken? Surely you jest. That's like looking for sand on a beach!!
BigJimAK is offline
post #4 of 6 (permalink) Old 06-12-2010, 12:41 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Alex. Glad to have you as a new member of our community.
Dave
the "Doctor"
Dr.Zook is offline
post #5 of 6 (permalink) Old 06-12-2010, 06:17 AM
AxlMyk's Avatar
There is a screw that adjusts the clamping pressure. It might need a slight tightening. It's located at the hinge end of the clamp.
AxlMyk is offline
post #6 of 6 (permalink) Old 06-12-2010, 10:36 AM Thread Starter
First Name: alex
thanks everyone. And i have messed with the clamp, it holds fine once it clamps. but when i lift it up, and then go deeper in the wood, it shifts on me. So it will be clamped somewhat offset. I couldnt find any of those posts.
Freud FT3000VCE 3-1/4 HP Variable Speed Plunge Router Bridge General Routing 9 11-01-2010 08:18 PM
New Plunge Base or New Router schenkelini General Routing 8 02-04-2009 02:21 PM
Sears Plunge Router Model 315.275110 Wally99 Table-mounted Routing 3 12-24-2008 06:39 AM
