Is it possible to cut groves in Cork Laminated wood? - Router Forums
post #1 of 6 (permalink) Old 06-27-2010, 12:01 AM Thread Starter
First Name: Johnny
Default Is it possible to cut groves in Cork Laminated wood?
I want to cut V groves into a piece of wood that is laminated with 1/8 inch cork and I was wondering if the cork will cut smooth or pull apart. I want to know if it can be done before I destroy a piece.
JohnnyB60 is offline
post #2 of 6 (permalink) Old 06-27-2010, 06:08 AM
First Name: Gene
Hi Johnny. My guess would be that it would pull apart...maybe someone on here has done it?
If not, and if you could do this with the workpiece, I wonder if clamping a thin board on top would prevent it from getting chewed up? Short of any other input, I think that's what I'd try.
swampergene is offline
post #3 of 6 (permalink) Old 06-27-2010, 06:25 AM
Gene Howe's Avatar
First Name: Gene
Depends on the denseness.
I have beveled edges of cork on board to make sanding blocks, never grooved any, though.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #4 of 6 (permalink) Old 06-27-2010, 07:48 AM Thread Starter
First Name: Johnny
Thanks guys. I guess Iím going to have to make a test piece to see.
I forgot about cork coming in different densities and now that you mention it, I do remember a bulletin board I once had that would fall apart if you looked at it wrong. That thing only lasted a week before it ended up in the trash.
This stuff I got looks like its pretty high quality and if Gene was able to bevel the edges on his, I think Iíve got a chance. Iím hoping that itís glued down evenly, which itís appears to be.
I saw this done once on a long wall with urethane coated cork to make it shinny. I donít know if it was manufactured 4x8 panels or if someone routed it during the installation but it looked pretty cool for what it was.
post #5 of 6 (permalink) Old 06-27-2010, 08:20 AM
HI Johnny - If that one had a couple of coats of urethane on it before it was routed I think it would work. Makes the bits a mess to clean though.
John Schaben
jschaben is offline
post #6 of 6 (permalink) Old 06-27-2010, 09:20 AM Thread Starter
First Name: Johnny
I never thought about that. It was too long ago for me to remember much about the details.
I do remember that the wood underneath was a light colored wood, perhaps pine or something and I believe it also had urethane. I just assumed that they were sprayed. Actually I can’t remember if it were groves or T-slots. There were large paintings hanging on it and it could have severed as hangers.
The only reason that I remember the urethane was because they had track lighting with flood lights for the paintings and the walls looked so clean and shinny. I’m not fond of all wood walls because they look dirty to me.
Squaring plywood panels ShaneB Table-mounted Routing 46 10-14-2009 05:28 PM
circular cut halteh General Routing 13 04-29-2009 06:08 AM
Router Planer Sled? Thinnest youíve cut wood? Nickbee Jigs and Fixtures 1 11-19-2007 10:51 AM
Wood scorching during cut?!!! Birch Tools and Woodworking 8 04-01-2007 08:56 AM
laminated pine defect reds_21 Tools and Woodworking 19 02-22-2005 09:25 AM
