Troeble with Craftsman router - Router Forums
post #1 of 2 (permalink) Old 07-03-2010, 12:29 PM Thread Starter
Reynaldo's Avatar
Country: Suriname
First Name: Reynaldo
Default Troeble with Craftsman router
I have a Craftsman Router, model 315.269210, which have been working properly, until all of a sudden I could not regulate the depth of the routerbit.
The ring, used to control the depth, is not moving anymore. I tried using WD40, but to no avail.
Is this a common problem with this router, and is there a solution for the problem? Hope someone can be of help.
Reynaldo
Reynaldo is offline
post #2 of 2 (permalink) Old 07-03-2010, 02:01 PM
dutchman 46's Avatar
First Name: Howard
Hello Reynaldo! Sorry for the trouble You'r having. I have hrard of that before, and I believe that sawdust might be stuck in the ring. I can't get into explaining what I"think", because I would have to guess, but somebody may be able to help You. O know that the solvents can get You into worse problems because wood can swell from that. I hope that some one will give You some real help. Thanks for joining. You will find out that there are many ppost here to help You!
John 3:16
dutchman 46 is offline
Craftsman router won't start wwkibler General Routing 12 12-23-2017 06:14 AM
Craftsman Router with Wolfcraft® Folding Router Table WoodCrazy Table-mounted Routing 2 01-05-2010 01:12 AM
Craftsman Router Not Working Properly cosmokramer General Routing 13 10-15-2009 06:28 AM
