router bits - Router Forums
post #1 of 4 (permalink) Old 07-14-2010, 02:14 AM Thread Starter
lparker's Avatar
First Name: leon
Default router bits
hi juys
just a quick question?
does anyone know how deep do i place the bit inside the collet????
lparker is offline
post #2 of 4 (permalink) Old 07-14-2010, 04:52 AM
First Name: Ken
Originally Posted by lparker View Post
hi juys
I would say all the way to the bottom of the collet then pull out about 1/16".
You could add a rubber grommet to the collet this way you don't pull out any more just push the bit all the way and lock the collet ,the grommet will give you that 1/16" space in the bottom.
distrbd is offline
post #3 of 4 (permalink) Old 07-14-2010, 08:55 AM
hi juys
Hi Leon, Ken is pretty much right on about dropping it in and pulling it back out about a 1/16". The rubber grommet idea generally works pretty well but I will say I have some larger bits that the grommet will leave an uncomfortable (for me) amount of shank showing. I also have some shorter bits that won't quite make the depth of cut I need, especially on the table, so I will pull them up a bit. In NO case will I have less than about 90% of the shank in the collet. Hope this helps
John Schaben
jschaben is offline
post #4 of 4 (permalink) Old 07-18-2010, 08:21 AM Thread Starter
lparker's Avatar
First Name: leon
cheers for that guys
lparker is offline
Replacement Router Bits for the Craftsman Router Crafter Brian in Burlington Router Bits - Types and Usage 1 11-17-2009 11:33 AM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
another sorry question about router bits reds_21 General Routing 7 12-30-2004 04:31 PM
