Bosch Colt Palm Router is Unsafe - Router Forums
 74Likes
post #1 of 83 (permalink) Old 07-20-2010, 04:56 PM Thread Starter
First Name: Rob
Default Bosch Colt Palm Router is Unsafe
I have been safely woodworking with commercial power tools for over 30 years. That means no injuries. But, I recently suffered a pretty scary cut while using a Bosch Colt Palm Router. It was set up with a 1Ē laminate trim bit with about 1/8Ē of the bit protruding out of the base and most of the bit exposed in the collet access opening cut out. In other words, the motor was adjusted high up in the housing, maximizing exposure to the spinning collet and upper part of the laminate bit through the unprotected collet access opening cut out in the side of the base. The fingers of my right hand were positioned on the base in the finger support pockets as per instruction. When I switched the Palm Router on with my left hand it moved/jerked into the laminate edge and bounced away from the work piece. Unfortunately, my fingers slipped out of the finger support pockets and into the unprotected collet access opening cutout in the side of the router base. Needless to say the top half of the laminate bit took a big chunk out of the tip of one of my fingers that slipped into the opening.
After reviewing the design of this tool it seems to me that some sort of plastic guard should cover the collet access opening cutout. Placing fingers close to the unprotected business end of this particular tool, as per instructions, seems to be very unsafe.
Has anyone else had a similar experience with this tool?
Echonav is offline
post #2 of 83 (permalink) Old 07-21-2010, 01:17 AM
Rob, this is the first problem report I have heard of. To date all members have raved about the Colt, I believe it is the most popular trim router at this time. While I am sure you harbor ill will for the Colt, perhaps you could leave it unplugged and take some step by step photos of how this occured? A picture is worth a thousand words. I am sorry to hear of this mishap and wish you a speedy recovery. I will bring this to the attention of a Bosch factory rep.
post #3 of 83 (permalink) Old 07-21-2010, 10:07 AM Thread Starter
First Name: Rob
I agree that the Palm Router is a great tool. I have been using it for years. But, after the accident, I took a closer look at it's design and the design of other laminate trimmers. Take a look at the picture. Do you see that large opening that exposes the spinning collet and bit? Now, consider that the user is supposed to place their fingers within 3/4" of the spinning collet and bit. Simply put, this is not safe. There should be a plastic guard in place.
By the way, as I recall, no other trim router has this kind of opening that exposes fingers to danger.
Ray Y likes this.
Echonav is offline
post #4 of 83 (permalink) Old 07-21-2010, 10:18 AM
Hi Rob
If you use the base below you are safer, you have a place for both hands. the chips must get out some how..
Amazon.com: Woodhaven 8320 Bosch Colt PR20 Bushing Plate: Home Improvement
Plus it has a real plus you can use the PC guides easy with this plate..
post #5 of 83 (permalink) Old 07-21-2010, 10:25 AM
Cochese's Avatar
First Name: C
First thing that pops in to my mind is, instruction manual or not, why would anyone put their fingers there?
The 144 Workshop - Ambitious but rubbish woodworking
Cochese is offline
post #6 of 83 (permalink) Old 07-21-2010, 10:33 AM
Doesn't appear to be anywhere else to hold the thing. Glad Rob posted this and I think Bj's link is a pretty good solution.
Here's a link with demo pics of how you need to hold it.
http://www.cpotools.com/factory-reco...d-palm-routers
Ray Y and DesertRatTom like this.
John Schaben
jschaben is offline
post #7 of 83 (permalink) Old 07-21-2010, 10:37 AM
Hi Chris
I can see how he did it, it's very easy to wrap your hand around the base , that's why it's best to have a place for both hands..many use just one hand and put one hand on the stock but the knob on the base will keep your fingers out of the bit hole.. it must be a every day thing that's why someone came up with the base plate with the knobs.
post #8 of 83 (permalink) Old 07-21-2010, 10:41 AM
Cochese's Avatar
First Name: C
Maybe I see it a different way, but I'd automatically hold it with my thumb and forefinger wrapped around just under where the power cord protrudes. A couple of my Ryobi tools have that same kind of mold to it.
:shrug:
Cochese is offline
post #9 of 83 (permalink) Old 07-21-2010, 10:48 AM
With fairly small hands and arthritic thumbs I doubt I could one-hand the thing. Next time I get close enough one for touchy-feely will need to handle it some
John Schaben
jschaben is offline
post #10 of 83 (permalink) Old 07-21-2010, 10:57 AM
Cochese's Avatar
First Name: C
I'd try dinner first.
Cochese is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.routerforums.com/general-routing/22786-bosch-colt-palm-router-unsafe.html
Posted By For Type Date
Bosch Palm Router This thread Refback 01-07-2011 06:55 PM
Bosch Palm Router - Canadian Woodworking and Home Improvement Forum This thread Refback 07-25-2010 11:03 AM
Bosch Palm Router - Canadian Woodworking and Home Improvement Forum This thread Refback 07-25-2010 10:11 AM
Bosch Palm Router - Canadian Woodworking and Home Improvement Forum This thread Refback 07-24-2010 10:20 PM
Bosch Palm Router - Canadian Woodworking and Home Improvement Forum This thread Refback 07-24-2010 09:54 PM
Bosch Palm Router - Canadian Woodworking and Home Improvement Forum This thread Refback 07-24-2010 09:52 PM
Sold: Bosch Colt router with loads of accessories **SOLD** Bob N Woodworking Classifieds 1 06-23-2009 07:12 PM
Colt plunge base bobj3 Jigs and Fixtures 19 04-01-2008 07:54 PM
Bosch Colt Trim Router..... Does Yard Work challagan General Routing 7 07-27-2007 12:52 AM
