which collet to get - Router Forums
post #1 of 10 (permalink) Old 07-21-2010, 12:15 PM Thread Starter
First Name: glenn
Default which collet to get
I have a craftsman router that is an older model. And i am not sure which collet i need to get for it. There is a bolt that screws on the motor spindle. Obviously i don't know that much about routers so i took a picture of it, to help explain what i am talking about. Sorry for the bad pic.
Silenus is offline
post #2 of 10 (permalink) Old 07-21-2010, 12:34 PM
Hi Glenn
Not to sure what you mean, you have one on the router now,it looks like 1/4" one but that's the only one that you can use on it..model number would help..
post #3 of 10 (permalink) Old 07-21-2010, 01:05 PM Thread Starter
First Name: glenn
The one that is on it now is 1/2 but i thought there was suppose to be a part that went down into the motor spindle that holds the shaft in place. Im sorry if i am not making sense, I don't know that much about routers and i want to make sure i buy the right thing and it will work safe. The router is a craftsman 3hp plunge model number 315.275040.
Thanks for replying.
Silenus is offline
post #4 of 10 (permalink) Old 07-21-2010, 03:03 PM
Hi
Looks like you are set to use 1/2" shank router bits,if you want to use 1/4" shank router bits you can pickup adapter that will work for you,see below, here's a copy of the parts manual that you may want to look over.
Part number 70,71,72 looks like they are in place.
http://www.searspartsdirect.com/part...0054819&blt=06
MLCS Woodworking Adaptor Bushings and Ball Bearing Guides
post #5 of 10 (permalink) Old 07-21-2010, 04:50 PM
Picture is kinda dark but I'm not sure I see a collet in there. Is it just the collet nut?
John Schaben
jschaben is offline
post #6 of 10 (permalink) Old 07-22-2010, 06:36 PM Thread Starter
First Name: glenn
Yes it is just the nut. The collet is what i need, but why on the sears part list is it called "sleeve" or is that the wrong part?
Silenus is offline
post #7 of 10 (permalink) Old 07-22-2010, 07:32 PM
Hi
If you are sure the sleeve is what you need and that part is 40.oo you may want to get the one below and put yours on the back burner for a bit..
Craftsman Plunge Router Industrial Electronic - eBay (item 230500941844 end time Jul-25-10 18:45:17 PDT)
post #8 of 10 (permalink) Old 07-22-2010, 09:43 PM Thread Starter
First Name: glenn
Thanks BJ,
yea if the part was only a couple of dollars it would not be that big of deal if it was the wrong part. But it being what it is, i am probably gonna either buy the one you linked or another one.
Silenus is offline
post #9 of 10 (permalink) Old 07-22-2010, 09:50 PM Thread Starter
First Name: glenn
Or should i just buy a brand new one?
Silenus is offline
post #10 of 10 (permalink) Old 07-22-2010, 11:26 PM
Hi Glenn
3 1/2HP routers are not cheap you would be hard pressed to find one for less than 200.oo dollars the norm new, I would say go for the 35.oo dollar one and see what the top bid is in 3 days then go from that point.
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Makita 3612 collet nut and collet cone needed cheap Zappacat General Routing 5 07-18-2009 12:33 PM
Installing bits in a tight collet Rowantree General Routing 8 07-09-2009 10:51 AM
How far to insert collet adapters? TWheels General Routing 3 05-28-2008 04:18 PM
Taste ? (about collet) Benny LaBaw Lobby 11 07-15-2007 08:57 PM
