template routing - Router Forums
post #1 of 5 (permalink) Old 07-30-2010, 02:09 PM Thread Starter
Default template routing
Hi, Grampa John here.
I have a few products that I want to produce in small volumes. I am trying to figure out what is the best way to template router them. most will have to be routed from all sides. Other than getting a cnc router what do you think might be the easiest. I have 2- 3 1/2 horse routers. one in a table & one for hand held, they are both plunge types. all ideas welcome.
grampaww is offline
post #2 of 5 (permalink) Old 07-30-2010, 05:48 PM
xplorx4's Avatar
First Name: Jerry
Greetings John and welcome to the router forum. We are pleased to have you join us.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 5 (permalink) Old 07-30-2010, 07:23 PM
Gene Howe's Avatar
First Name: Gene
Hi John, and welcome!
You should get many replies to your query. There are several guys with several great methods who contribute to the forum.
Personally, I use an over arm pin router (router mounted on an arm above a table with a pin in it) to follow a pattern. Depending on their sizes, I can duplicate several different parts at one time.
No need for collars and offsets or pattern/trim bits. Just a 1/4" spiral and a 1/4" pin.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 5 (permalink) Old 07-30-2010, 07:44 PM
Hi John
The pin router can do a nice job but if you don't have a pin router than a standard router table will do a good job just fine.
Just make your master template ,use some 1/4" MDF stock, pin nail the template to the blank the stock and than chuck up a good trim bit and go for it, if the bit is a good trim bit you don't need to use the band saw the trim bit will plow right into it..and give you copy after copy of the master template..
Spiral Flush Trim Router Bit
MLCS solid carbide router bits
post #5 of 5 (permalink) Old 08-01-2010, 12:17 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the router community Grampa. Thanks for making our forum better by registering.
Dave
the "Doctor"
Dr.Zook is offline
Routing Template Verlin Garrett Jigs and Fixtures 16 08-17-2019 09:12 PM
Routing + Template Confusion prav1988 General Routing 8 05-27-2009 08:54 AM
Routing with Template Tom template tom Guide Bushings and Templates 82 04-14-2009 02:25 AM
template routing woodyone General Routing 4 11-20-2008 01:53 PM
