Triming Deck Boards - Router Forums
post #1 of 2 (permalink) Old 07-31-2010, 09:42 PM Thread Starter
lkesslii's Avatar
First Name: Skip
Default Triming Deck Boards
I have just finished a mini-deck (4' x 8') and wanted to know if anyone has had experience using a straight cut router bit with a bearming to trim the overhanging boards? I was thinking that this would be better than a circular saw since the cut with a CS would have to be free hand due to position of deck.
The boards are 5/4 by 8 and I only want to trim the end of the boards so that means end grain.
Any ideas and lessons learned would be appreciated!
lkesslii is offline
post #2 of 2 (permalink) Old 07-31-2010, 10:29 PM
Skip, with a board clamped as an edge guide you can easily get a clean straight cut. Just go slow so you don't get tear out. You can wrap the board ends with masking tape for added protection against this problem.
Planing with a Router Gilbear Portable Routing 51 05-17-2012 04:40 PM
Two Tier Deck TRN_Diesel Show N' Tell 28 06-30-2010 01:40 AM
First Cutting Boards Soapdish Show N' Tell 3 02-03-2010 10:35 AM
Finish for a new cedar fence and deck with? hoondog70 The Finishing Touch 5 08-03-2009 08:54 AM
Jointing long boards Jtomwoods Table-mounted Routing 8 05-25-2008 09:05 PM
