Routing edge inlay - Router Forums
post #1 of 7 (permalink) Old 08-04-2010, 12:32 PM Thread Starter
Default Routing edge inlay
Hi all,
Go easy as i am new to the posting side of the forum!!!!!
I am going to build a chest of drawers from ash and have considered edging the drawer fronts with a darker strip to give a bit of decoration, but also trick the eye into not seeing the gaps round the drawer and the frame.
I was considering routing a rebate all the way round the drawer then just glueing in the banding. ( Maybe 6mm wide)
I am unsure if this would ping off over time when the drawer is used.
Would I be better with cock beading?
Thank's
Shortie
Shortcut is offline
post #2 of 7 (permalink) Old 08-04-2010, 05:39 PM
TwoSkies57's Avatar
Hey shortie.. welcome to the community...
What kind of drawer design are you considering?
Dovetailed, butt joint, glue joint, mitered etc....
Skipper the Penguin
TwoSkies57 is offline
post #3 of 7 (permalink) Old 08-04-2010, 07:30 PM
Gene Howe's Avatar
First Name: Gene
I'd go with the cock bead, depending on your gaps' widths. Unless you make your own bead tool and round it by hand, the bead stock will need to be near 1/4" thick. At least I can't find a router bit to round over thinner stock.
You could lay in contrasting wood, as you suggested, and make a cock bead of the same wood. Might look pretty cool.
As an aside, I used cock beading on a dresser and applied it to the openings rather than the drawers. Worked well.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 7 (permalink) Old 08-08-2010, 02:48 PM Thread Starter
Thank's for the replys.
Dovetail drawers sides will be the construction route.
I have been looking at stringing..strips that can be purchased for the job, it would just mean routing a rebate to the correct depth round the drawer front.
Shortcut is offline
post #5 of 7 (permalink) Old 08-09-2010, 07:04 PM
RJM60's Avatar
First Name: Robert
RJM60 is offline
post #6 of 7 (permalink) Old 08-09-2010, 08:30 PM
Thanks for that RJM60
vikingcraftsman is offline
post #7 of 7 (permalink) Old 08-09-2010, 09:57 PM
Hi Guys
Use the bit below and make 3 in one pass then cut them off with the band saw/table saw with the 1/16" wide 6 1/2" diam. saw blade installed on the table saw. ..
1 pc 1/2" Shank with 1/8" Rad. Triple Bead Router Bit - eBay (item 130413104472 end time Aug-21-10 19:53:17 PDT)
Sign Board Edge Routing eball30263 Sign Making 10 07-24-2013 02:54 AM
2X4 edge routing Thrake 2 General Routing 5 03-26-2010 02:21 AM
routing a previously routed edge Fishbaydoc Router Bits - Types and Usage 7 08-31-2009 11:40 PM
routing edge on round tom41 Jigs and Fixtures 34 01-06-2009 08:19 PM
Routing edge on plywood Dimitri Guest General Routing 2 10-20-2004 02:34 PM
