mitre lock bits - Router Forums
post #1 of 5 (permalink) Old 08-05-2010, 12:53 PM Thread Starter
First Name: Randy
Default mitre lock bits
I am interested in using mitre lock bits to make the mitred corners on speaker cabinets. I am an experienced cabinet maker, and I used to live and die by my routers ( at one time I had eleven routers, I was so proud! ), but I have never used a mitre lock of any kind. I wondered if anybody could give me any advice. Thanks!
gnarlywood is offline
post #2 of 5 (permalink) Old 08-05-2010, 01:17 PM
RJM60's Avatar
First Name: Robert
I have two but haven't used them yet. I understand they can be a bear to setup properly but ince done, they work very well. Also, you should create a setup gauge once you have them setup. It should be the same thickness as the pieces you're mitring and you should mark it with the thickness and keep it.
Also, the pieces being mitred should be the same thickness.
That's all I know so far. I suspect that it would be recommended not to use these bits in plywood but I would probably try it anyway.
RJM60 is offline
post #3 of 5 (permalink) Old 08-05-2010, 06:19 PM
First Name: Chris
Depending on which brand you buy, you can actually get a corresponding "quick set" jig. Freud and Sommerfeld both have them. Its basically just a plastic gauge type tool that you align with the cutter. Once the tool slides into the cutter correctly, you are at the correct bit height. The tool adjusts for different thickness materials, and it works for much more than just the normal 45 degree lock miter bit.
If you go with another brand, you would just use the trial and error method (which actually isnt that bad....after a few tries I had my Whiteside lock miter almost perfectly dialed in for some HD-bought pine that I was playing with)
The joint it creates sure is nice. I read a how-to where someone suggested "burnishing" the corner of the joints, to create what looks like a seamless piece. I might give it a shot (I think they suggested just a stiff piece of plastic to round over each sharp miter edge). its possible, though, if the joint is tight enough that paint or the glue itself could just fill it nicely.
chrisexv6 is offline
post #4 of 5 (permalink) Old 08-06-2010, 09:05 AM
First Name: Steve
I used one to make speaker cabinets in MDF!! Not the best material but I must say that I am pleased with the result. You do need a solid and tall vertical fence on the table and setting it all up can be a pain until you get your head around it and then it is easy. I found some advice on this forum which I will try to find again.
Steve
Here's the set up data I used :- http://www.mlcswoodworking.com/shops...ockmtr0911.pdf
Barreller is offline
post #5 of 5 (permalink) Old 08-06-2010, 07:15 PM
To burnish a corner joint you just need a round shaft like the shank on a screwdriver. You rub the corner joint to fold the edge into each other to help close the joint up even more. This sometimes will help the joint look like a tight fit, but it can't hide a joint that is just open too much.
Whittier, CA.
Have a nice & safe day!
jlord is offline
intro and mitre lock bits gnarlywood New Member Introductions 5 08-06-2010 04:13 PM
Two sizes of lock miter bits. Which do I need? dawziecat Router Bits - Types and Usage 13 01-23-2010 10:29 PM
Miter lock bits & Melamine jd99 Tools and Woodworking 9 11-20-2009 03:26 PM
Lock Mitre Router Cutter Ianelm1930 Router Bits - Types and Usage 9 10-24-2009 03:18 PM
using 22 1/2 lock miter bits without bearings magicgary Router Bits - Types and Usage 5 07-24-2009 03:44 AM
