Used mills as roter bits? - Router Forums
post #1 of 7 (permalink) Old 08-05-2010, 10:15 PM Thread Starter
First Name: Bob
Default Used mills as roter bits?
I have access to discarded mills at work from our machine shop. They were used for cutting aluminum. Some are brand new. Can I use them in my router on wood?
Bob95065 is offline
post #2 of 7 (permalink) Old 08-05-2010, 11:57 PM
Country: Germany
First Name: Titus
If they are still sharp (ish) then yes.
I use 10mm HSS milling cutters that I acquire from work with no problems.
They give a nice clean cut as most have three continuous cutting edges.
Titus A Duxass is offline
post #3 of 7 (permalink) Old 08-06-2010, 12:06 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the forums Bob. The new end mills I think you can use, but I wood be hesitant in using old ones. You need really sharp cutting edges in wood.
Dave
the "Doctor"
Dr.Zook is offline
post #4 of 7 (permalink) Old 08-06-2010, 12:16 PM
dutchman 46's Avatar
First Name: Howard
Hello Bob, I have a ton of new, and used. They will work. But remember that they aren't made for that and may cause some problems with clean routing of certain materials. They are HS steel ?
John 3:16
dutchman 46 is offline
post #5 of 7 (permalink) Old 08-06-2010, 04:49 PM
Soapdish's Avatar
First Name: Jake
I just started using some this week. Same thing here, i have access to them at work. Used ones can be found in the trash in the machine shop. I'm using some really tiny ones (1-1.5mm) for outlining a sign I'm tinkering with. They cut through wood like butter. The only thing I was worried about is that instead of the .25" shaft diameter is actually .23, so I have to use most of the threads on the collet.
My favorite thread on routerforums.com. Great Posts
Soapdish is offline
post #6 of 7 (permalink) Old 08-08-2010, 07:35 PM Thread Starter
First Name: Bob
Most of the mills I find are solid carbide. I am not sure how easy they would be to sharpen.
I need to find some adapters for my 1/2" collet. Some of the mills are 3/8" Does anyone know a source for an adapter?
Bob95065 is offline
post #7 of 7 (permalink) Old 08-08-2010, 08:13 PM
Try here: Whiteside Router Bits from Woodworkersworld.net--Router Accessories
These are a little cheaper:
http://www.toolstoday.com/nsearch.as...shing&x=9&y=12
I think MLCS and EagleAmerica have them too.
Good Luck
John Schaben
jschaben is offline
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
End Mills vs.Rrouter Bits For Mortising. Gaia Router Bits - Types and Usage 8 07-03-2010 12:37 PM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
Need help deciding on bits. ryan.s General Routing 8 03-25-2005 09:35 PM
