Makita RP2301 insert plate - Router Forums
post #1 of 3 (permalink) Old 08-13-2010, 03:38 PM Thread Starter
First Name: Dawid
Default Makita RP2301 insert plate
I'm looking for a table insert plate for the new Makita RP2301 router. The Incra magna lock seems like a reasonable choice but I see they only have one listed for the previous 3612 model. Does anyone know whether it will fit ? No replies so far from the company. Anyone attached this router to a table yet?
post #2 of 3 (permalink) Old 08-17-2010, 02:10 PM Thread Starter
First Name: Dawid
Seems like the new Makita RP2301fcx is just that, very new. Not one of the companies involved was able to tell me whether the pre-drilled insert plates for the Makita 3612C would fit the Rp2301. I found a shop that still had both models and the little bolts at the bottom is in the same evenly spaced 12,3,6 and 9 o'clock position and measures the same.... so it will fit.
post #3 of 3 (permalink) Old 08-17-2010, 05:18 PM
Hamlin's Avatar
First Name: Ken
Hi,
You can always make your own plate. You already have a template to do the job. The sub plate that's already mounted.
Ken
"A VETERAN"
Hamlin is offline
Samona Insert Plate bill0199 Table-mounted Routing 9 01-06-2012 02:30 PM
Insert plate orientation Cochese Table-mounted Routing 8 01-16-2010 04:54 PM
Router insert plate opening size rcp612 Table-mounted Routing 21 01-10-2010 02:14 PM
Rockler large blank plate bushing insert..... Duane867 Table-mounted Routing 25 12-07-2009 06:36 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
