bought new router - Router Forums
post #1 of 10 (permalink) Old 08-16-2010, 02:27 PM Thread Starter
JClamp's Avatar
First Name: Jeff
Thumbs up bought new router
I just bought new Ryobi router, need to know what are the best bits to get started with building fairly simple bookcase for my son's family. Any leads (websites, etc.)?
JClamp
JClamp is offline
post #2 of 10 (permalink) Old 08-16-2010, 02:51 PM
First Name: Mischa
It all depends on what kind of joinery you are going to use. You said "fairly simple", so I am going to assume that you'll be using dados/rabbets. In that case, all you need is a good set of straight bits.
There are many good places to get decent bits. I'll pick MLCS Woodworking here: MLCS Router Bits and Woodworking Products
If you are going to use plywood, then you either need to use special plywood bits (3/4" plywood is generally not 3/4" but a bit thinner), or you need to make a dado/rabbet jig that will allow you to use smaller-diameter bits to make larger-width dados/rabbets. See here: MLCS Straight & Plywood Straight Router Bit Sets
The best straight bits are solid-carbide compression bits. They are expensive, but they'll give you the least amount of problems.
Next best would be solid-carbide upspiral or downspiral bits (depending on intended use). Priced similarly as the compression bits.
Next best would be straight bits with shear action.
Next best would be 'normal', run-of-the-mill straight bits (see link above).
Knock yourself out!
Cheers! MM
xvimbi is offline
post #3 of 10 (permalink) Old 08-16-2010, 03:00 PM
Default Bought a New Router
I would agree that the MLCS carbide bits are an excellent starting point. Take a look at Amazon.com and you will find what I would call a "starter set" for a very reasonable price point. I would also suggest that find a copy of: Woodworking with the Router: Professional Router Techniques and Jigs Any Woodworker Can Use (American Woodworker) by William H. Hylton. This is a terrific reference book that will provide you with an amazing amount of information.
Enjoy,
Phil Stevens
hillsboro is offline
post #4 of 10 (permalink) Old 08-16-2010, 03:01 PM
Hi
I would suggest the set below to start off with.
MLCS 15 Piece Router Bit Sets
JClamp
post #5 of 10 (permalink) Old 08-17-2010, 12:07 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Jeff & Phil. Glad to have you aboard.
Hillsboro is where Phil?
Dave
the "Doctor"
Dr.Zook is offline
post #6 of 10 (permalink) Old 08-17-2010, 12:42 AM
xplorx4's Avatar
First Name: Jerry
Greetings Jeff and welcome to the router forum. We are pleased to have you join us.
Lamentations 3:22-23
xplorx4 is offline
post #7 of 10 (permalink) Old 08-23-2010, 01:53 PM Thread Starter
JClamp's Avatar
First Name: Jeff
Thanks Bj,
I will definitely check these helpful links out. I do still have some old bits left from my Craftsman router, but not sure they are sharp enough.
JClamp (JeffC)
JClamp is offline
post #8 of 10 (permalink) Old 08-23-2010, 02:22 PM Thread Starter
JClamp's Avatar
First Name: Jeff
Smile Greetings veteran woodworker
Your statement is accurate, scraps are also used often in my wood projects. will update profile when I get my required posts completed!! Thanks, JClamp (JeffC)
JClamp is offline
post #9 of 10 (permalink) Old 08-23-2010, 02:29 PM Thread Starter
JClamp's Avatar
First Name: Jeff
Smile Greetings to you
Great lead in welcoming me! God gave us no limitations, just believe in him and yourselves. Look forward to your forum in the future.
JClamp (JeffC)
JClamp is offline
post #10 of 10 (permalink) Old 08-23-2010, 08:00 PM
First Name: Robb
Since you have bits from your Craftsman you have already done some basic routing. I buy a lot from Rockler. Carbide bits are the best and last the longest. If you are building bookcases there are a lot things you can do with a router - round over on shelves and decorative edges, etc.
Have at it! Safety First.....................
Robb is offline
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
