Porter Cable runs hot - Router Forums
post #1 of 6 (permalink) Old 08-18-2010, 06:16 PM Thread Starter
Default Porter Cable runs hot
I have a PC 890 that I bought a few years back and use exclusively for table routing. Recently, the tool runs so hot after fifteen minutes or so that it is uncomfortable to change the bit. I tried blowing it out, seemed pretty clean and still runs hot. What is wrong?
fishlore is offline
post #2 of 6 (permalink) Old 08-18-2010, 06:36 PM
Hi Bill - my guess would be a bearing went out on you. Since you have been running esclusively in the table, I'm thinking items 14 & 15 on this explode.
Porter Cable 890 Parts List and Diagram - Type 1 : eReplacementParts.com
If I were going to change those, I would also change item 24 and the brushes.
Good Luck
John Schaben
jschaben is offline
post #3 of 6 (permalink) Old 08-18-2010, 07:36 PM
Hi Bill
Benny LaBaw found some great videos for the PC and others that will help you replace the bad parts..below you will find a link for the replacement parts and his forum help web site.
http://forums.ereplacementparts.com/
YouTube - Porter Cable Router Armature Removal
YouTube - Bosch 1611 & 1615 Router Bearing Removal
Router Forums - View Single Post - PorterCable 890 become HOT. Can I fix it ?
http://www.routerforums.com/tools-wo...can-i-fix.html
post #4 of 6 (permalink) Old 08-19-2010, 06:46 PM
First Name: David
Fishlore, I agree with the other two RF guys, but while your at it, you might get some spray cleaner for electrical components and clean the field and the armature. Also, use some fine emery cloth and make sure the contact point for the brushes is well cleanedon the armature also.
Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time...
UnionLabel is offline
post #5 of 6 (permalink) Old 08-20-2010, 09:25 AM
First Name: Jimmie
Bill, I agree with all above coments, the bearings are the most common defective parts to make a router get that hot. They are relativity easy to replace and sure make an older router perform like new especialy after a good cleaning and brush replacement. A screwdriver, small puller and impact are all the tools you will likely need. V/R Robbie
robersonjr is offline
post #6 of 6 (permalink) Old 08-23-2010, 07:07 AM Thread Starter
Many thanks to you kind gentlemen for the diagnosis and treatment advice. I shall get started on the surgery forthwith.
fishlore is offline
Bosch 1617vs Verses 690 Porter cable Glenmore Tool Reviews 20 08-09-2009 09:36 PM
Porter Cable circular saw crquack Tools and Woodworking 11 03-29-2009 06:33 PM
porter cable 894 runing hot kenwho General Routing 6 06-01-2008 08:15 AM
