Island project - Router Forums
post #1 of 8 (permalink) Old 08-21-2010, 11:12 AM Thread Starter
Wizard1500's Avatar
First Name: Carl
Default Island project
We have the below island in our kitchen. The side being viewed is the back and end. My wife wants me to cover those two sides with pine...(we are redoing our entire kitchen in pine.....I've already built the cabinets for the dining room half, and will install them in about a week. I plan to run 4" wide boards vertical. I am thinking about routing v-grooves vertical, to add some character.....my question is this: If I run the grooves at the glue joints, will that weaken them too much.....I would think that there really will not be any tension to deal with.....I plan to attach by small screws from inside the cabinet.....all opinions will be greatly appreciated.....
Carl.....
Wizard1500 is offline
post #2 of 8 (permalink) Old 08-21-2010, 02:59 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Carl
It isn't a problem at all. If you use 4 pc V-Joint & Assembly Tongue & Groove Router Bit Set - eBay (item 140443422275 end time Aug-28-10 09:44:10 PDT) you can do it at one set up.
Cheers
Peter
istracpsboss is offline
post #3 of 8 (permalink) Old 08-21-2010, 09:58 PM
Carl.....
Carl,
I don't normally do this when some one has a plan in mind, but I think a pine frame and panel section would look great over that area.
Sydney, Australia
jw2170 is offline
post #4 of 8 (permalink) Old 08-22-2010, 03:44 AM Thread Starter
Wizard1500's Avatar
First Name: Carl
James, I agree 100%, but my wife didn't really want that, when we discussed it.
post #5 of 8 (permalink) Old 08-22-2010, 05:29 AM
Haha Carl,
Then it is best to agree with your wife....
Please show us some photos when the project is done.....
Sydney, Australia
jw2170 is offline
post #6 of 8 (permalink) Old 08-22-2010, 06:29 AM
allthunbs's Avatar
First Name: Ron
Hi Carl:
Ok, pine verticals will work. Careful when you cut your tongue and groove. Use feather boards so they come out nice and straight and even. When You apply them to the plywood, I like the idea of screws from the back side but I'm not partial to glue. First, are you using oil (alkyd) paint? Second, leave a slight gap 1/32-1/16 (no more) to allow for expansion and contraction of the wood. A kitchen is a terrible place for heat and humidity. Next, I would drop a bit of glue in the middle of the width of the board at each end but none in the grooves. Allow them to move when they breathe.
Allthunbs
allthunbs is offline
post #7 of 8 (permalink) Old 08-22-2010, 08:35 AM Thread Starter
Wizard1500's Avatar
First Name: Carl
Thanks for the tips, Ron......I will be covering the pine with a satin polyurathane.....that will match the cabinets that I will install.....eventually, I will replace all the cabinets in the kitchen, and they too will be pine with poly. I assume, on this pine facing, I should cover the face side and the back???......
post #8 of 8 (permalink) Old 08-22-2010, 09:59 AM
allthunbs's Avatar
First Name: Ron
I don't know about the poly. The last kitchen I did was with a special "kitchen" latex and that was disastrous. My wife's choice, not mine. She was talked into it by the paint "specialist" at the store. By the time I was done with them, they stopped carrying the paint. My worry about the poly is that it is too porous for a kitchen. Check with the experts will you? Make sure you do all sides and ends of the boards before you install them. Also, I'm assuming that you're going to screw through the plywood that you've got there already?
gotta go. eaves troughs.
Allthunbs
