Vacuum extension hoses for a router - Router Forums
post #1 of 23 (permalink) Old 08-22-2010, 03:57 PM Thread Starter
First Name: Lon
Default Vacuum extension hoses for a router
My Craftsman router has a standard 1 1/4 port to attach a vacuum hose.
Craftsman makes a small compact vacuum with a 4 ft 1 1/4 hose. Their next product up the line also has a 1 1/4 in hose which is 7 ft.
Over at Sears I asked about extension hoses. They showed me a 1 7/8 which they said is all they had.
Well all this is confusing.
Looking at the project in the Better Homes and Gardens Wood magazine issue #199
for Sept 2010 there is a nice project for a sanding station which could adapt to a router table. This could be done once all this hose business is straightened out.
I guess the primary question is: how can I get a 1 1/4hose extension which can be used with the small Craftsman vacuum as a separate item? If a part number and description is necessary, I'll find that.
Here: http://www.sears.com/shc/s/p_10153_12605_00917713000P
loninappleton is offline
post #2 of 23 (permalink) Old 08-22-2010, 04:05 PM
First Name: Jason
A search on ebay for "shop vac hose" turned up several hits on the first page. Id post the link but I dont think I can for 2 more posts
jaydubya is offline
post #3 of 23 (permalink) Old 08-22-2010, 04:17 PM
TwoSkies57's Avatar
Lon...
if you wish to go from the 1 1/4" to a 1 7/8" hose..here is the adaptor sears offers..
http://www.sears.com/shc/s/p_10153_1...7827000P?mv=rr
you can go from 1 1/4 to 1 7/8 then 1 7/8 to 2 1/2 and then put on just about any length hose you like...
here is the ebay link for 1 1/4" vac hose that I think Jason may have been referring to
1 1 4 vac hose items - Get great deals on Home Garden, Business Industrial items on eBay.com!
ebay: shop vac hose listings
http://shop.ebay.com/i.html?_nkw=sho...286.m270.l1313
Skipper the Penguin
TwoSkies57 is offline
post #4 of 23 (permalink) Old 08-22-2010, 07:29 PM
dutchman 46's Avatar
First Name: Howard
I believe that the hose they had is for the 5 horse vac. The person may have thought that He new about the product. Apparently, He doesn't
John 3:16
dutchman 46 is offline
post #5 of 23 (permalink) Old 08-22-2010, 09:30 PM Thread Starter
First Name: Lon
Well I now know ebay has something anyway. They don't look biddable though. At $40
(when shipping is included) I could prob'y get the 5 hp vac with the 7 ft hose when on extreme markdown. I'll keep an eye out for deals.
I already have one of those 1 1/4 to 2 in adapters. I think that is for specific diameter change for the Ryobi sander in the Wood mag piece or to a larger vac with 2in standard Shop Vac style fittings. For this application a 1 1/4 extension should be enough. I'll not take back the adapter. That was $3.50 or so.
The Wood magazine extension shows a 1 1/4 to 1 1/2 "compression coupler" to connect the vacuum end. Down at Ace they didn't know exactly what a Schedule 40 compression coupler was. Anyway the compression coupler should attach to the
sleeve end of the vaccum cleaner hose. That's to build the whole S-shaped design for above the table.
I'll see if I can find a pic at Wood mag.
post #6 of 23 (permalink) Old 08-22-2010, 09:56 PM
Hi lon - I put myself through something of an ordeal a few months ago trying to get all my handheld stuff hooked up to my shopvac dust collection wanna be. Depending on how flexible you need it, I did find some 1 1/4 ID hose at HD that was sold in bulk. A little to stiff if you need to move it around but worked ok for "pig tails" on most of my handheld stuff. I then found some thin wall PVC fittings (under sink stuff) that would function as couplers in the plumbing department. I also found that a lot of the cheaper upright vacuum cleaners (Bissel was one I think) use 1 1/4 stretchable hose and got some of that dumpster diving. Some of those also have neat little 90* elbows attached. Managed to get everything hooked up except my B&D hand planer which has an irregular shaped port and Bosch finish sander with an oval port. . I also found some stuff that looked really promising by the submersible pumps but sending high velocity air through it would make it howl like a banshee. Worked just fine until you got a length of about 5 ft and it would raise such a ruckus.
Point is, there are alternatives out there. Hope this helps
John Schaben
jschaben is offline
post #7 of 23 (permalink) Old 08-23-2010, 05:48 AM
First Name: Howard
The one thing that I want to tell You is that there is no comparison when setting the two together. The 5 Hr. will develop a great deal of suction. It can pick-up much more, and will draw it from a foot, or so. My grandson has the small one, and I have the large one. Mine is over ten years old. Just so You know. Enjoy!
John 3:16
post #8 of 23 (permalink) Old 08-23-2010, 04:48 PM
Jack Wilson's Avatar
First Name: Jack
Have you tried swimming pool filter hose?
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #9 of 23 (permalink) Old 08-23-2010, 05:34 PM
TwoSkies57's Avatar
Jack...
have you used pool hose?? thoughts on it?
Skipper the Penguin
post #10 of 23 (permalink) Old 08-23-2010, 09:57 PM
First Name: Jack
Originally Posted by TwoSkies57 View Post
Jack...
No I have not, I know its really for PRESSURE, as opposed to vacuum, but maybe with a smaller vac it would be fine, and it is inexpensive enough for a trial, (I think).
Jack
T/S Router Extension dwall174 Table-mounted Routing 24 04-15-2010 09:53 AM
Router Table Extension - Attachment and Alignment GarethR Table-mounted Routing 1 11-20-2009 12:47 AM
MLCS Router Bit Extension dimensions cadcraig Starting Off 4 08-27-2008 01:33 AM
Router Bit Extension rmaxa Router Bits - Types and Usage 35 01-14-2008 05:05 PM
