DW 618 won't power on - Router Forums
post #1 of 6 (permalink) Old 08-22-2010, 07:29 PM Thread Starter
First Name: Derek
Default DW 618 won't power on
Hi folks,
I'm hoping you can help me out with what is probably a simple problem and can be chalked up to a rookie user. I have got a brand new DW618 that I have mounted into a Wolfcraft table. I've never used the router before. I'm bypassing the switch in the table and plugging it directly into an outlet (that works) in my garage, but when I flick the toggle it won't come pn. The cord is in and locked, the locking lever is secure and I have a bit securely fasted in the collet. Is there a failsafe somewhere that is preventing it from coming on because perhaps I've done something wrong?
Any thoughts you may have would be appreciated.
Thanks in advance,
Derek
Dlynden is offline
post #2 of 6 (permalink) Old 08-22-2010, 09:18 PM
hilltopper46's Avatar
First Name: Tony
I do not have thios router so I am venturing where I should not. I do see the following in an online manual that I found:
Detachable Cord Set (Fig. 1)
Insert the detachable cordset plug so that the key (W) is aligned with the notch (V) in the
socket. Turn the plug clockwise one quarter turn to lock.
Are you sure the cord is inserted and seated correctly?
hilltopper46 is offline
post #3 of 6 (permalink) Old 08-22-2010, 09:37 PM
Hi
Just a long shot
"The unique switch and cordset configuration allows you to keep the switch in your right or left hand..."
Did you pull the switch ..you may need to tape the switch down to the on position..
Originally Posted by Dlynden View Post
Hi folks,
Thanks in advance,
Derek
post #4 of 6 (permalink) Old 08-23-2010, 09:13 PM Thread Starter
First Name: Derek
Default Thanks all
Thanks for the quick responses. After seating and re-seating several times yesterday, I tried again today and low and behold I have ignition. I assumed that the cord would not move to the locked position unless seated properly, but it appears I was wrong.
Again, I appreciate the quick answers folks. I'll try to add a little more value next time I post.
Derek
Dlynden is offline
post #5 of 6 (permalink) Old 08-24-2010, 08:55 PM
First Name: Tony
I'm glad you got it going - and, BTW, welcome to the Router Forum. I'm pretty new here myself and much more a wood butcher than a wood worker, but there is a lot of good advice on this forum.
post #6 of 6 (permalink) Old 08-24-2010, 11:56 PM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. Thank you for joining us.
Lamentations 3:22-23
xplorx4 is offline
Extension cord + power strip: advice needed xvimbi Tools and Woodworking 15 07-16-2010 10:55 AM
Bosch Power Tools Buys Freud's Accessory Line dovetail_65 Lobby 2 01-17-2009 12:21 PM
Power! istracpsboss Lobby 4 10-26-2008 10:14 AM
Rockler Safety Power Tool Switch 1/3 off Ladd The Bargain Bin 3 12-16-2007 03:45 PM
power supply/extension cord questions rprice54 Tools and Woodworking 10 06-28-2006 04:31 PM
