Locking knob lost - Router Forums
post #1 of 5 (permalink) Old 08-26-2010, 09:32 AM Thread Starter
Default Locking knob lost
Hi - I'm a newbie as you will surely guess from my questions...
I inherited some tools including a router from my Dad, but no manual. It is a Craftsman 315.174771 fixed base model. According to the parts list on the Sears site there should be a locking knob which I believe locks the bit depth after adjustment. Sears no longer carries this part.
When I tried to use the router I found that the bit (and the housing) move vetically about 1/8 to 1/4 inch quite freely unless I apply some downward pressure as I operate it.
So my questions are:
1. Is the bit supposed to move up and down relative to the base when you press down/lift up the router?
2. Is the locking knob essential?
3. If so, can I simply use a nut, bolt and perhaps a spacer through the flanges in place of the knob?
Thanks for any advice...
Dan
d. aubin is offline
post #2 of 5 (permalink) Old 08-26-2010, 09:37 AM
Hi Dan
1. = No
2. = Yes
3. = Yes
Dan
post #3 of 5 (permalink) Old 08-26-2010, 10:31 AM
Dan
Hi Dan, Welcome to the forum.
Looks like you just need a square head bolt, small spacer and knob. Knob may be a bit difficult as it is a long one to allow hand clearance around the base but just use another spacer between the knob and the clamp. Most any fair sized hardware store should be able to fix you up.
John Schaben
jschaben is offline
post #4 of 5 (permalink) Old 08-26-2010, 12:33 PM Thread Starter
Thanks Bob and John. Now I can get going. I think I'll practice on some scrap when I get the locking knob problem solved.
Dan
d. aubin is offline
post #5 of 5 (permalink) Old 08-26-2010, 02:09 PM
Hi
It's hard to find any sq.head bolts now days but you can buy sq, nuts that you can braze on a standard bolt or some all threaded rod, the knob you can your own like below with a long sex nut (stand off ) or wing nut..
Name:	old router table AB.jpg
Missing locking key on router Rowantree General Routing 2 07-11-2009 04:14 AM
Locking Miter Router bits woodworker319 Router Bits - Types and Usage 6 02-20-2009 06:47 PM
Locking Miter George II General Routing 3 02-18-2008 07:05 PM
Locking mitre joints for picture frames grandsire02 Table-mounted Routing 3 08-10-2007 01:56 AM
Lost my Shop partner today kp91 Lobby 6 02-17-2005 10:55 AM
