Inner plate on router base - Router Forums
post #1 of 6 (permalink) Old 08-30-2010, 02:56 AM Thread Starter
Country: South Africa
First Name: patrick
Default Inner plate on router base
Good Morning
This might sound like a stupid question, but why is there different size inner plastic plates. Surley one hole big enough for all bits would suffice. Why I am asking is because I want to build my own router table. I am going to make a new stainless steeel base plate as the one I have(Ryobi) ist not a very nice one. Living in South Africa we dont get all the spares as in europe or to USA.
Thanx
patrick kane is offline
post #2 of 6 (permalink) Old 08-30-2010, 10:31 AM
CanuckGal's Avatar
First Name: Deb
The different size plates that cover the holes are for different size bits. If you use a smaller bit in a large hole, the wood has a tendency to "dip" into the hole and mess up the cut as well as create a DANGEROUS situation. The part could be pulled into the hole and your fingers pulled into the spinning router bit.
Always use the plate that allows just enough clearance for the bit. This will give your stock lots of support and a nice finish to your cut.
I measured, I marked, I cut.
CanuckGal is offline
post #3 of 6 (permalink) Old 08-30-2010, 03:34 PM Thread Starter
First Name: patrick
Thanks now it makes sence
post #4 of 6 (permalink) Old 08-30-2010, 08:09 PM
zerodyn is offline
post #5 of 6 (permalink) Old 08-30-2010, 11:46 PM
BigJimAK's Avatar
The additional support of a the ring closeby decreases tearout on the bottom side, too... akin to a "zero clearance" throat plate on a saw.
BigJimAK is offline
post #6 of 6 (permalink) Old 09-02-2010, 04:02 AM Thread Starter
First Name: patrick
thanx
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 09:00 AM
Router Plate Installation Rutabagared Project Plans and How To 11 01-14-2012 07:15 PM
Model 320.17542 and table routing 46_trap Table-mounted Routing 44 10-16-2011 01:40 PM
Router Base Plate Question dabeeler Table-mounted Routing 3 12-24-2008 01:21 PM
