True Router Speed - Router Forums
post #1 of 7 (permalink) Old 09-06-2010, 12:47 PM Thread Starter
Default True Router Speed
Many have ask about router speed and charts, this is one I put up to help others with that job..
Let me say,, Not all routers are the same
The P.C. battery type router below
No Load..../ with a load, used a 1/2" bit for the load in some 3/4" MDF 1/2" deep.
without load 23,454 .... down by -20 % with load.
Sears Craftsman #17543 without load////with load,down by %
Number #1 speed setting 16,124 .....-40%
Number #2 speed " " " 18,506 ....-35%
Number #3 speed " " " 21,620 ....-30%
Number #4 speed " " " 24,526 ....-25%
Number #5 speed " " " 26,729 ....-20%
Number #6 speed " " " 26,880 ....-15%
http://www.sears.com/shc/s/p_10153_1...2&blockType=G2
http://www.amazon.com/Porter-Cable-9.../dp/B00005QEVT
Checked with the tool below
Amazon.com: Neiko Professional Digital Laser Photo Non-Contact Tachometer - Accurate to 99,999 RPM Measurement: Home Improvement
post #2 of 7 (permalink) Old 09-06-2010, 05:24 PM
First Name: Al
BJ....yes, I get your drift. Its similiar to the horsepower of trucks. the horsepower at the flywheel compared to the horsepower at the rear wheels via the gear box and diffs.That could be a reduction of 20 plus percent.Same as router speeds? .............AL
Al Robins is offline
post #3 of 7 (permalink) Old 09-06-2010, 06:02 PM
BigJimAK's Avatar
Very interesting stuff, BJ.. I don't doubt your test or your findings, but am curious.. How did you apply your load, so it'd be the same in each test?
BigJimAK is offline
post #4 of 7 (permalink) Old 09-06-2010, 06:14 PM Thread Starter
Hi Jim
" with a load, used a 1/2" bit for the load in some 3/4" MDF 1/2" deep."
I Used the same bit for all the test speeds on both routers..
post #5 of 7 (permalink) Old 09-06-2010, 11:49 PM
BigJimAK's Avatar
I was thinking in terms of feed speed / force, but OK..
BigJimAK is offline
post #6 of 7 (permalink) Old 09-07-2010, 09:54 AM Thread Starter
Hi Jim
Thinking like a Electrical Engineer again I see LOL and not the KISS way
post #7 of 7 (permalink) Old 09-07-2010, 11:23 AM
BigJimAK's Avatar
Hi Jim
As Popeye would say, "I yam what I yam!"
BigJimAK is offline
Modulated speed router problem. seanburns General Routing 6 08-19-2013 08:20 AM
Router Speed Control Mounting BigJimAK General Routing 13 04-14-2010 09:21 PM
Router Speed Control Switch fieldsd General Routing 6 07-05-2009 04:36 PM
Router Speed Guide CanuckGal Starting Off 9 12-25-2008 04:52 PM
