Depth adjusting ring will not turn - Router Forums
post #1 of 5 (permalink) Old 09-10-2010, 05:17 PM Thread Starter
First Name: Doug
Red face Depth adjusting ring will not turn
Hi everyone. I have a Craftsman portable router model #315-175110. The router works perfectly well, except that the depth adusting ring will not turn; this is a 1-3/4 HP variable speed router. Any suggestions for solving this problem will be greatly appreciated.
thank you - Doug
drm1021 is offline
post #2 of 5 (permalink) Old 09-10-2010, 07:25 PM
HI Doug
That's a real down fall with the Craftsman router with the ring, I would suggest you blow it out well, the router dust fills the grove up with chips and dust most of the time, than move it one direction and than the other, once it's free a little bit blow it out again, it can take a bit of work to get it free,,DON't put any oil on it, should be just a dry fit..you can put a bit of water on it for a lube but blow it out well after it will not rust but the saw dust will make a mash...if you don't get it all out..
Good Luck
thank you - Doug
post #3 of 5 (permalink) Old 09-11-2010, 05:40 AM
dutchman 46's Avatar
First Name: Howard
Hello Doug! Welcome to the forum. I agree with BJ, Do not push it to hard, Gust work it. Plastic isn't to forgiving.
John 3:16
dutchman 46 is offline
post #4 of 5 (permalink) Old 09-12-2010, 09:29 AM
Hey Doug,
Have a Craftsman 315 series 2 HP motor unit. My unit's depth adjustment froze up too. After hours of fussing with it, I decided to disassemble the entire unit(was off warrantee anyway). Removed the motor assembly, switch, brushes so all that was left was the body. Came apart easily & not complicated, just took care not to crimp or pull on the wiring.
Set the base in a padded vise & gently but firmly worked the unit until it started moving. I did use a silicon lube spray that dried quickly but left enough of a film to make the unit slide a little more easily. Like BJ & Dutchman suggested, blow it out thoroughly with an air hose. Again, wiped off any residue & it cycled it up & down a few times until it moved like new again. Did notice that the "stop" peg in the groove gets hung up easily & care should be taken to make sure it's aligned. Reassembled the unit, a total of ten screws, four in the motor, four in the cover & one each for the sleeves that hold the brushes. I'm more shocked than anybody that it works like a champ again but will use my 24 year old Black & Decker router with a base plate adaptor on my Craftsman router table. Just use this router for regular duties. Other than this problem, it has always done a great job for me.
Tom
Nockmoi is offline
post #5 of 5 (permalink) Old 09-13-2010, 11:33 AM Thread Starter
First Name: Doug
Default Many thanks to all who answered
thank you - Doug
Just wanted to say thanks to everyone who answered my question. I still use my Skil plunge router for the larger jobs, but the smaller Craftsman is ideal for the smaller job ones.
Thanks again - Doug
drm1021 is offline
Craftsman 315.175040 Router Depth Adjustment gloftis Starting Off 8 05-02-2020 06:52 AM
adjusting depth how to figure out the right depth CFLfan Portable Routing 3 02-06-2010 06:22 PM
trouble adjusting the depth of my Craftsman router JohnnyB60 General Routing 7 06-19-2009 06:13 PM
Depth adjusting ring doesn't turn. waynecathy33 New Member Introductions 4 11-17-2008 11:35 PM
pc 890 series depth adjustment rabuckner General Routing 4 04-10-2005 01:20 PM
