Creating Tapered Flutes - Router Forums
post #1 of 4 (permalink) Old 09-11-2010, 10:52 AM Thread Starter
Default Creating Tapered Flutes
I'm experienced with rough woodworking, but am just beginning to tackle what would be considered "fine furniture" quality stuff.
I'm building a new aquariums stand, trying to match my wife's antique african mahogoany dining room set. I need to reproduce the triple tapered flutes that are the main motif on these pieces.
I don't know how to get the tapered ends, and I'm nervous about getting these tapers correct... and since there are three very close together, if they're not all identical they will look terrible.
The only other info I've found is here: finehomebuilding.com/how-to/departments/master-carpenter/router-jig-for-cutting-tapered-flutes.aspx (I couldn't post the URL as a link cuz I'm too new.)
And of course it looks easy... but first I'll have to make that sled, so that's a whole other project that I'm not sure how to approach.
Brett Agostini is offline
post #2 of 4 (permalink) Old 09-11-2010, 11:46 AM
The jig is basically two wedge (tapered) pieces one on each side. On top of these sits a piece of thin ply to use as a ramp for the router to rise up on. The tapered ramp allows the router to be gradually lifted up which will give you the tapered flutes. The ramp should have a slot for the bit to stick thru as it will be below the router base plate. You may need to sand a bevel on the edge of ply where it hits on your tapered ramps.
You will need to fasten everything to a table top or a piece of 3/4" ply will be fine. Make four tapered pieces, two for each side. Cut a piece of ply for a base to fasten router to wide enough to overhang your tapered pieces. You will need a fence on bottom piece of ply for your base to reference on for the length of flutes. Making it adjustable would be nice. Just look at the picture & you can see all the parts needed. The adjustable fence for the base plate is probably the most complicated part in the jig.
Here is the link for you.
Router Jig for Cutting Tapered Flutes - Fine Homebuilding Article
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 4 (permalink) Old 09-15-2010, 11:19 AM
So you guys can make flutes?
alexleonardme is offline
post #4 of 4 (permalink) Old 09-15-2010, 11:49 PM
BigJimAK's Avatar
Yes, Alex... though not the musical instrument, if that's what you're thinking... Here's a picture and one way to make them..
Tapered Stop Flutes
BigJimAK is offline
Creating Interest Doak Guide Bushings and Templates 18 07-01-2009 06:36 AM
nujmber of flutes or wings? awoodnut Router Bits - Types and Usage 4 06-12-2009 03:03 AM
Fine Tapered Finger joints jn_capili New Member Introductions 8 01-14-2009 09:26 PM
template jig for making tapered legs asrubin Jigs and Fixtures 3 04-12-2008 06:40 PM
making long flutes CABDOR Tools and Woodworking 4 06-03-2006 12:05 AM
