Angled dado? - Router Forums
post #1 of 9 (permalink) Old 09-11-2010, 12:57 PM Thread Starter
First Name: Nancy
Default Angled dado?
Does anyone have any articles or input that will help me figure out how to make angled dadoes with a router for the sides of a ladder? I want to make a simple ladder for an interior loft and want to make sure that my dadoes for the steps are exactly the same angle but cannot find info on how to set up a jig. Thanks in advance.
NSavidge is offline
post #2 of 9 (permalink) Old 09-11-2010, 01:28 PM
Hi Nancy
Here's quick and easy jig you can use and make for the angle dado's..
Do both sides of the ladder at the same time and than rip the stock to size that way they will match up at glue up time..
Sometimes it's best to just buy one with all the springs/hardware.
Amazon.com: Louisville Ladder L224P 250-Pound Duty Rating Wooden Attic Ladder Fits 8-Foot 9-Inch to 10-Foot Ceiling Height, 22-1/2-by-54-Inch Ceiling Rough Opening: Home Improvement
Louisville Ladder S224P 8' 9" Wood FLD Attic Ladder
post #3 of 9 (permalink) Old 09-11-2010, 05:55 PM
RJM60's Avatar
First Name: Robert
Hi Nancy
This won't work since the stringers are mirror images of eachother. They need to cut separately but the jig should work fine as long as the first dado is in the same place. Small errors will not be noticed.
RJM60 is offline
post #4 of 9 (permalink) Old 09-11-2010, 06:31 PM
Hi Robert
I think it will, once it's ripped down the center and flipped over and end to end the dado slots will line up..
OR your can use a pair of boards tape them up as one wide board, put the dado slots in place, than trim the ends to match the dado angle cuts..
Start with some 1 x 6 x 8ft poplar stock, put in the dado slots, then rip and flip.. make you steps 4' wide so you have a bit of over hang, than screw and glue the up ladder..
Pull out a pad of paper and draw it out than cut it down the center and flip it..
post #5 of 9 (permalink) Old 09-11-2010, 07:57 PM
BrianS's Avatar
First Name: Brian
Hi Nancy. Here is what I did to solve that problem. Check here: Jig help needed Pic of the jig that I came up with is near the end.
Brian
(Origin uncertain)
BrianS is offline
post #6 of 9 (permalink) Old 09-12-2010, 08:05 AM
First Name: Mischa
Hi Robert
It think it will, once it's rip down the center and flipped over and end to end the dado slots will line up..
Bob's jig will work, provided it can be used as shown as well as after flipping it around the horizontal or vertical axis (like BrianS's jig), thus turning it into its mirror image.
Cheers! MM
xvimbi is offline
post #7 of 9 (permalink) Old 11-05-2011, 11:48 AM
First Name: Micah
A somewhat related question: I want to route dados angled not relative to the edge of a board, but angled relative to the face of the board. Picture a book reader-holder, with a flat base, and then a board say 10 degrees off vertical (dado-ed into the base) to hold your book or ebook reader. OK to attach a scrap to a board so its angled and run over a straight bit on the router table?
Micah is offline
post #8 of 9 (permalink) Old 11-07-2011, 11:51 AM
RJM60's Avatar
First Name: Robert
1. Make a wedge shaped baseplate for your router. God if you need a stopped dado (i.e. not thru the edges of a board).
2. Use a table saw with the blade set at 10°. Will need to be a thru dado. Could also be done with a circular saw.
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #9 of 9 (permalink) Old 11-14-2011, 01:09 PM
First Name: Micah
Aha. Thank you much. About the table saw: I do everything with a router because I don't have a table saw; but that is going to change next week (a loaner). Yahooooo. AND, I just bought a nice used Jet jointer for $340 to be delivered tomorrow. -mds
Micah is offline
Adjustable Dado Jig for Plunge Router diggerop Jigs and Fixtures 3 11-08-2009 02:47 PM
Dado on 2 sides of 3/4 plywood for cubby shelves aquilja4 General Routing 3 11-06-2009 08:17 AM
Adjustable Dado jig - setup problems rovenm Jigs and Fixtures 2 09-21-2009 02:06 PM
Adjusting groove & dado widths. rstermer Portable Routing 22 08-10-2009 04:39 AM
Dado cuts in plywood BK9MJE Tools and Woodworking 4 04-18-2009 01:28 PM
