easy way to set depth on fixed base? - Router Forums
post #1 of 14 (permalink) Old 09-15-2010, 10:19 PM Thread Starter
First Name: Paul
Default easy way to set depth on fixed base?
Using a plunge router, I follow these directions. Its really straight forward and makes perfect sense to VERY easily set the proper depth (i use drill bits... so easy).
What would a similar process be for a fixed base router? I've always had to have a scrap piece around to test cut, measure (so on and so forth)... There has to be a more reliable way that im just not seeing...
Reason I'm asking is my father (whom I'm going to see this weekend) only has a fixed base router at his house and would like some help making a few things. Just looking for a fast more reliable method
Someone shed some light on this apparently not thinking straight beginner...
g19fanatic is offline
post #2 of 14 (permalink) Old 09-15-2010, 10:56 PM
Hi Paul. For my fixed bases I just sit the thing upside down on the bench, put a drill bit or bar stock next to the bit and adjust till they're flush and lock it down.
John Schaben
jschaben is offline
post #3 of 14 (permalink) Old 09-17-2010, 05:24 AM
First Name: Vern
I use a set of brass bars from Whiteside for many of my setups,they come as a set in 1/8th
increments, they come in handy for setting tablesaw depth as well.All of the woodworking stores carry these,cost us about 10 bucks.
Toolfool is offline
post #4 of 14 (permalink) Old 09-17-2010, 06:35 AM
If you are going over to help can you just take your router if it is easier for you to set up?
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #5 of 14 (permalink) Old 09-17-2010, 09:19 AM
Hi Paul
They sale a tool just for that type of setup, you can wire tie it to the router plug cord so you always have it at hand when needed..Plus a good way to make sure you pull the plug when you are working on the bits...I also wire tie the router nut, that I'm not using at the time to the end of the power cord..
Router Depth Gauge
Router Depth Gauge - Rockler Woodworking Tools
post #6 of 14 (permalink) Old 09-17-2010, 01:20 PM Thread Starter
First Name: Paul
@bobj
thanks for the link. I will have to pick one up as this is definitely a very easy method
@jlord
not @ home is the issue... multi-stop trip with his request happening after i left home :/
The problem I have with using either brass bars or drill bits is that you still have to eye it up. I guess i'll have to get a small 'level' so that I can level the router bit tip and measuring tool (either be it bars or drill bits) off of the router base. That will give repeatable results. I guess i'm just being picky, I like methods where you don't have to do any real double checking and its just second hand nature... Got to that point w/ my plunge very quickly even in just one project...
Thanks for your guys info
post #7 of 14 (permalink) Old 09-17-2010, 01:31 PM
You're Welcome Paul ,it's not the best but it works ,the KISS way and it gets the new user in the habit of pulling the plug every time.
@bobj
@jlord
post #8 of 14 (permalink) Old 09-17-2010, 11:44 PM
BigJimAK's Avatar
Great *Safety* tip as well as being practical, BJ!!!
Hi Paul
Router Depth Gauge
BigJimAK is offline
post #9 of 14 (permalink) Old 09-18-2010, 05:25 AM
Thanks Jim
Most forget the Golden rule " be safe 1st." than do it the KISS way..
post #10 of 14 (permalink) Old 09-18-2010, 05:55 AM
allthunbs's Avatar
First Name: Ron
Except when you're using the handles in plunge or edge treatment mode then the gauge always catches on the edge of the work or somewhere else that is extremely inconvenient. It's bad enough that the cord gets caught, it's worse when there's something tied onto the cord. If you're using the router freehand or with the handles and an edge bearing, you might consider a plug in the ceiling and some sort of suspension to help cord management when doing critical cuts. I use a bungie cord when necessary. If you do a lot of large size hand work, the bungie cord sliding on a metal clothesline works a treat.
Allthunbs
allthunbs is offline
plunge or fixed base bellaw Table-mounted Routing 16 01-08-2014 04:49 AM
Freud 2200E -- How do I set it up for a measured depth plunge cut? Ladd General Routing 8 11-12-2007 03:23 PM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 12:56 PM
Pitting in PC plunge base DONALD Tools and Woodworking 5 12-04-2004 10:36 PM
Converting fixed base to plunge base. -Sam- Portable Routing 4 09-30-2004 03:53 PM
