Trouble with bushing & lock collar vibrating loose - Router Forums
post #1 of 19 (permalink) Old 09-18-2010, 11:06 PM Thread Starter
Lightbulb Trouble with bushing & lock collar vibrating loose
Some time ago I saw a comment on the use of a thin spring or wave washer to solve the problem of the lock collar/ bushing set-up from vibrating loose during use. Does anyone know of such a piece of hardware? All the washers I'm able to find are too thick to do any good on a router. Has anyone had success with other means of lock collar retention?
:wackowoodtick:
papabear42 is offline
post #2 of 19 (permalink) Old 09-19-2010, 01:06 AM
BigJimAK's Avatar
John... I'm sure there are cheaper ones elsewhere but here's one source I stumbled on while ordering some bushing reducers to use my 1-3/8" bushings in my 1-3/4" (LV / OP) router base plate.
Router Bushing Spring Washers
BigJimAK is offline
post #3 of 19 (permalink) Old 09-19-2010, 07:35 AM
BrianS's Avatar
First Name: Brian
John, I got mine at Home Depot, but any hardware or home supply store should have them.
Brian
(Origin uncertain)
BrianS is offline
post #4 of 19 (permalink) Old 09-19-2010, 08:57 AM
Hi John
If you have a drill press and a 6-32 nylon screw you can make the ring a locking type easy...just drill a 1/8" hole on the edge of the brass ring and tap it out with 6-32 hole, then put the nylon screw in place but just a little bit you should see the tip of the nylon screw inside of the brass ring than cut it off the nylon screw with a sharp knife, touch the end of the screw on the grinder or belt sander to clean up the end and your done..all done with a .02 cent fix..that works
Note***it will be real tight the 1st.time you use it but the guide will cut the threads on the nylon and than it works just right after that.. just that little drag it needs..
post #5 of 19 (permalink) Old 09-20-2010, 12:32 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Anyone tried wrapping PTFE plumbing tape around the threads?
Cheers
Peter
istracpsboss is offline
post #6 of 19 (permalink) Old 09-20-2010, 09:26 AM
Thumbs up
Hi John
Mercy - Bj Strikes again
Great idea - Washers work great but something else to fumble with and they can easily be misplaced. Teflon tape would probably work but needs to be reapplied every time, or almost every time. A replaceable nylon button seems to have all the upside and none of the down.
Well, only downside for me is I already bought 4 of the washers. I can use it on the big bushing though
John Schaben
jschaben is offline
post #7 of 19 (permalink) Old 09-20-2010, 10:46 AM
Hi John
Thanks ,here's just one more that works for the small brass guides and the bigger guides if you don't want to drill and tap the brass ring, a simple (very thin 1/16" diam.) O-ring that you can pickup up at the hardware store for .05 cents or less, pickup one that's a lot smaller than what you need and stretch it over the guide threads and push it all the way down to the lip.( 3/4" and a 1 1/8" works well) you will see them use in kitchen faucet repair kits.. but ACE hardware has a tray rack of them.
How it works,,,,when you put the nut in place it will compress the O-Ring and put the load on the brass threads and lock it in place..
post #8 of 19 (permalink) Old 09-20-2010, 07:49 PM
First Name: Howie
how about some loctite?
Howie is offline
post #9 of 19 (permalink) Old 09-20-2010, 08:04 PM
Hi Howie
Loctite is great stuff if you don't want to remove it .
post #10 of 19 (permalink) Old 09-20-2010, 08:58 PM
Depends on the color. The red and green stuff is pretty much permanent, need heat or an impact to break it loose. The blue stuff will come apart, probably with a couple of water pump pliers.
John Schaben
jschaben is offline
Rub collar for bushing jmoore65 Guide Bushings and Templates 0 03-06-2010 07:41 AM
Having trouble with 8mm router bit adapter bushing namans Router Bits - Types and Usage 4 09-22-2009 06:40 PM
Loose guide bushing Hat Guide Bushings and Templates 4 03-24-2009 09:56 AM
