1/4 to 1/2 adapter for craftsman router - Router Forums
 1Likes
post #1 of 12 (permalink) Old 09-19-2010, 03:40 PM Thread Starter
Default 1/4 to 1/2 adapter for craftsman router
I bought a router with 1/2 in shank and my router goes only to 1/4/ is there an adapter??
pat abraham is offline
post #2 of 12 (permalink) Old 09-19-2010, 04:14 PM
kp91's Avatar
First Name: Doug
You can get adapters to put 1/4 inch router bits into a 1/2 inch collet router, but there is no off the shelf adapter I know of to put a 1/2 inch shank router bit into a 1/4 inch collet router.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 12 (permalink) Old 09-19-2010, 06:32 PM
dutchman 46's Avatar
First Name: Howard
I believe that You may be putting Your life at risk, and no one makes the 1/4 to 1/2 bit adapter. The 1/4 in shaft of the router is normally not stout enough to handle the extra weight, and vibration when going through medium cuts. There capacity is 1/4 in. bits, and no bigger. The 1/2 in. router is no sweat. always can go slower.
John 3:16
dutchman 46 is offline
post #4 of 12 (permalink) Old 09-19-2010, 09:39 PM
Hi Pat,
Welcome to the forum.
I would not try and use a 1/2" router bit in a 1/4" router, even if an adapter was available.
Save the 1/2" bit until you can upgrade to a 1/2' router.
In the long run, you will spend more on good bits than a 1/2" router.
Sydney, Australia
jw2170 is offline
post #5 of 12 (permalink) Old 09-19-2010, 10:35 PM
Hi Pat
You can get most bit profiles in the 1/4" shank size like the panel bits and the R & S bits it's true you can get more in the 1/2" shank size but if all you have is a 1/4" router put it to work that way with the 1/4" shanks sizes...bits...
I will say you can make a adapter but the last time I said that it was like flying over Germany with tons flack coming at me... But I have one in my router tool box and it works..
But I will not tell you how to make one easy because I have to many holes in my wings from the last fly over
But like they say no guts no glory
http://stores.ebay.com/Super-Carbide-Tools
post #6 of 12 (permalink) Old 09-20-2010, 01:11 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the forums Pat.
Dave
the "Doctor"
Dr.Zook is offline
post #7 of 12 (permalink) Old 09-20-2010, 04:32 AM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. Thanks for joining us here.
Lamentations 3:22-23
xplorx4 is offline
post #8 of 12 (permalink) Old 09-20-2010, 06:08 AM
First Name: Howard
I see what Your asking: The best I can say is to check with the manufacture, If You have a manufacture bulletin , they will talk about it. I have a 1/2 in. router that uses a reducer. to go to i/4 in. Could You be so blessed ? If You have a Colet in Your nut for the i/4 in., You may have a bushing that slips out. It would help us a lot if You would give us information on the router, And at the same time, if You could add a name, and a location in the profile page, We will have the information to give You mush needed help.
John 3:16
post #9 of 12 (permalink) Old 05-05-2017, 02:01 AM
if your router is a craftsman go to sears parts direct and order a 1/2" collet. Thats what i did and it works fine and its safe. They charged me $8.99 for the part. But call do not order on line it will be twice the price
nooolongpants is offline
post #10 of 12 (permalink) Old 05-05-2017, 02:25 AM
for a craftsman router 1/2" collet call Sears Parts Direct and order part #2823125000. thats what i did and price was $8.99. if you order online its $16.99
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
I think my old router nearly killed me! peacefrog General Routing 23 01-26-2014 11:36 AM
