Routing 101 Question - Router Forums
post #1 of 2 (permalink) Old 09-21-2010, 07:11 AM Thread Starter
First Name: Ron
Default Routing 101 Question
I am going to be making a 17 inch on a side triangular table top from clear Alder with a template and edge trimmer. It will be an equilateral triangle with the grain perpendicular to one side. That results in kind of an end grain on all of the three sides.
I am concerned about the direction of the off table routing movement. I know that outside movement is generally counter clockwise, inside the opposite. Does that still apply since I would be going "against" the grain on one leg of the triangle, with the grain on another, and across the grain on the third. Should the direction be reversed where the bit would tend to lift the grain? Would I be better to try to flip the table top and route the third edge from the opposite surface of the top? Would small cuts minimize the problem? Is there even reason for concern?
I really don't want to mess this one up. Thanks for any help or advise.
rweerstra is offline
post #2 of 2 (permalink) Old 09-21-2010, 02:39 PM
Honored Member
First Name: pat
Would rout with collar and plunger & I would climb cut.
Making the plunge steps at a minimum, say ~3/32"/pass, you can rout CC or CCW without the machine trying to self feed.
Try on scrap first; expect few surprises.
Quillman is offline
Climb routing question Woodenhead Portable Routing 9 03-31-2009 05:33 PM
Routing MDF Question dadsalmon Table-mounted Routing 14 10-18-2007 07:02 PM
have question about routing andrew_patton Tools and Woodworking 1 08-08-2006 08:34 PM
Newbie Question on Routing jig-tables Cookie199 General Routing 2 02-19-2006 06:47 PM
