Which one of these 3 router should I get? - Router Forums
post #1 of 20 (permalink) Old 09-24-2010, 04:04 AM Thread Starter
First Name: anthony
Default Which one of these 3 router should I get?
Hi there!
Seems like I'm ready for my second router and after reading some reviews, I've narrowed down my choices to:
1- Bosch (1617evspk) 2.25 HP Combo router kit $209.00 at Lowe's
2-Craftsman 17543 11 amp 2 hp Corded Fixed and Plunge Base Soft Start Router with Electronic Feedback $99.00 at Sears
3-Craftsman Professional 28084 12.5 amp Corded Fixed/Plunge D-Handle Combination Router $149.00 at Sears
I don't have much use for the D-Handle, at least for now, I think, since I'm mostly making speaker cabinets, (dovetail, edges, circle cut) expecting to get into kitchen cabinets when I get more experienced.
I know the prices are all over the place, and it would be nice to save $, as long as I don't sacrifice quality and performance. I don't have a lot of experience with routers, I've been using mine (Harbour Freight 1-1/2 HP Variable Speed Plunge Router) for only a few months now.
Can somebody direct me to the better choice?
anthonylv64 is offline
post #2 of 20 (permalink) Old 09-24-2010, 05:50 AM
Cassandra's Avatar
First Name: Cassandra
Hi Anthony:
Welcome to the forums!
The Bosch 1617EVSPK usually gets high ratings from editors and users alike. It is a solid tool, reliable and very usable. I have one and don't regret buying it.
Like you, I don't have much (any) use for the D-handle and the lack of having one hasn't caused any problems.
As for the two Craftsman routers you listed, I don't know about them.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #3 of 20 (permalink) Old 09-24-2010, 06:55 AM
Raymondabel's Avatar
First Name: Ray
Send a message via Skype™ to Raymondabel
not replying to you question but:
Y looking for a 2hp if you look for "expecting to get into kitchen cabinets when I get more experienced."
The only major raison is if you wonna use it "free hands".
Buy yourself a 3 hp. Perso I am a Triton lover...
My 2 cents
Ray
Raymondabel is offline
post #4 of 20 (permalink) Old 09-24-2010, 07:49 AM
MikeMa's Avatar
I have had the Bosch 1617 for over 5 years now, and have been very satisfied with it. I have been thinking about getting a second one.
MikeMa is offline
post #5 of 20 (permalink) Old 09-24-2010, 09:33 AM
Hi
I would suggest you get the Professional 28084, you can use the D-Handle base in the router table if you want to, than you have a plunge base and a fix base for hand router jobs, it comes with a built in lift on all 3 bases, the red top router is a great router and that's a great price you can almost say you get 3 routers for one low price...take the 60.oo you can save and pickup some router bits if you are set on putting out 200.oo plus for a router..the Bosch as small down fall if you want to use brass guides down the road..other than that it's a good router..but it's a bit high in price..
Sears: Appliances, Tools, Electronics, Apparel and more from Craftsman, Kenmore, Diehard and other Leading Brands
Originally Posted by anthonylv64 View Post
Hi there!
post #6 of 20 (permalink) Old 09-24-2010, 10:24 AM
RJM60's Avatar
First Name: Robert
I have the Bosch and it's a good router but I have to agree that it's difficult to use a guide bushing on it. The center hole in the metal base is too small and when using PC style bushings, the adapter makes it even smaller
The $99 Craftsman looks like a decent router in the picture. One thing I noticed is that it looks like the plunge base has a spring on one side only but this may not be bad. the 1617 plunge base also has a spring on just one side. The $149 ("Red Top") Craftsman looks like it has a spring on each side. This may make the plunge mechanism smoother.
Both Craftsman routers have la arge opening in the base and either might be better for guide bushing use. They also both have a removeable motor (unlike some Craftsman models). The removeable motor gives you more options should you decide to buy/build a router table.
When I bought the Bosch, I was looking for a good plunge router. I inspected as many brands as I could in person and the Bosch seemed to have the smoothest plunge mechanism and just felt like a better design. The guide bushing thing is an issue but it's not too bad.
If you can actually inspect each of the roputers in person, I would recommend doing so.
Also, I don't know about these 2 Craftsman routers but, depending on the router plunge base, the locking mechanism works differently. On the Bosch 1617, the plunge base is always locked and the lever releases it. In use, you would:
1. Pull the lever.
2. Plunge the router.
3. Release the lever (locking the router in position).
4. Make your cut.
5. Pull the lever.
6. Raise the router.
It becomes quite natural.
I also have an Craftsman plunge router that has a mechanism that is always unlocked and pulling the plunge lever locks it. Using it would go something like:
1. Plunge the router.
2. Pull the lever (locking the router in position).
3. Make your cut.
4. Release the lever.
5. Raise the router.
This would work just as well, as long as the locking feature is smooth.
RJM60 is offline
post #7 of 20 (permalink) Old 09-24-2010, 11:12 AM Thread Starter
First Name: anthony
Thanks a lot for all your input. I guess I'll take some time today to visit the stores and closely inspect each of those routers, you all make great points, and one thing I'm noticing is that you can never have too many routers, lol. It looks that which ever I chose of those 3, it wouldn't be terribly wrong I guess. Thank you, guys.
post #8 of 20 (permalink) Old 09-24-2010, 11:45 AM
RJM60's Avatar
First Name: Robert
A couple things I forgot. The $99 Craftsman has a light (can be handy); the other 2 don't. Both Craftsman have shaft locks and require just one wrench to tighten/loosen collet. This is a personal preference. i find it easier to use 2 wrenches. Two wrenches allows me to leverage one against the other like a pair of pliers.
RJM60 is offline
post #9 of 20 (permalink) Old 09-24-2010, 08:11 PM
Cassandra's Avatar
Hi Mike:
We're on the same wavelength. Now that I have a router table, in which my 1617EVSPK router spends most of its time, a second 1617EVSPK is looking good for free-hand work.
Cassandra
post #10 of 20 (permalink) Old 09-24-2010, 10:42 PM
Hi
Just a add on Note,,,both Craftsman routers have work lights bright LED's in the motor head..plus a light showing the power cord is in the outlet..and is hot..just a safety item telling you to unplug b/4 working on the router...just in case you forgot to.
One more Note...the Craftsman 17543 has 3/8" diam.holes for the edge guide and the Craftsman Professional 28084 has 5/16" diam.holes for the edge guide, that's why I use the 17543 for my ski jigs..bit less power than the 28084 but you don't need a tank for the ski jigs but the bigger the hole the better...
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
Which Router To Get Etc? Gaia General Routing 10 02-24-2010 04:52 PM
How do I mount a Router to a table demaX Table-mounted Routing 3 04-16-2009 06:56 AM
