Just wondering...... - Router Forums
post #1 of 7 (permalink) Old 09-26-2010, 08:54 AM Thread Starter
Gene Howe's Avatar
First Name: Gene
Default Just wondering......
....if ya'll think that a ski mounted router would do the job of planing an end grain cutting board rather than using a planer?
I think I know the answer, I just want validation from the experts.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #2 of 7 (permalink) Old 09-26-2010, 09:07 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
No problem at all Gene because the skis like I use can be used in all directions so there should be no breakout.
Harry
harrysin is offline
post #3 of 7 (permalink) Old 09-26-2010, 09:29 AM
Honored Member
First Name: pat
Tho a router will do; it is not meant for this kind of surface duty.
Better choice: Get the bumps out of it with planes then commit to a thickness sander.
Quillman is offline
post #4 of 7 (permalink) Old 09-27-2010, 02:36 AM
harrysin's Avatar
First Name: Harry
"Tho a router will do; it is not meant for this kind of surface duty."
I rarely disagree with a member, even an anonymous one but having more years of routing experience than the majority of members have been on this earth, I can categorically state that the router is meant for whatever one's imagination can dream up. Sure, many, many years ago I thought that a router was for edge work then I made, and thought that it was my invention, what we all now know is a template guide which enabled me to make fancy shaped male templates from hardboard and rout around them. Years later and heaps of routing later I was fortunate in meeting an expert routologist and the things that I learned about the router made all those years of routing pale into insignificance. It's a bit like saying a screwdriver is only for turning screws, who hasn't at some time successfully used one as: a chisel, a scraper, a lever and I'm sure, many more things. these shots show my original template guide for my first B&D router that looked more like a drill!
Harry
harrysin is offline
post #5 of 7 (permalink) Old 09-27-2010, 05:47 AM Thread Starter
Gene Howe's Avatar
First Name: Gene
Harry, I'm thinking a bottom cleaning bit (surface planer on a small scale) would do the trick.
Gene Howe
Snowflake, AZ
post #6 of 7 (permalink) Old 09-27-2010, 05:55 AM
allthunbs's Avatar
First Name: Ron
Hi Gene:
Yes, the set of skis is the only way to go. (oops, a pivot frame will do it too!)
I would stay away from sandpaper. It will clog the pores of your workpiece and give you a cloudy finish. Instead, I would use:
1. skis or pivot frame. Do progressively smaller depths of cut until you get to within 1/32nd of your final thickness then take the rest down with a cabinet scraper. This will allow you to "fine tune" the end grain and give you a spectacular finish. Harry has some holding frames that will help nicely, too.
2. planer (as above) and then clean with cabinet scraper.
When you're using planes or a planer, make sure you oversize your workpiece just in case of tearout or other imperfections. This is not necessary with a router on skis. However, I wouldn't rely on the router bit for the finished cut. Use a cabinet scraper.
By the way, it would help if we knew where you were in the world but beyond that, we don't need your life story, detailed financial statement, description of your expensive workshop or any other personal information, in spite of what other's may say. You disclose what you wish or remain anonymous as is your want. No one here has a right to demand otherwise or restrain comment just because you chose to disclose less information than they do.
When a question is asked, please provide adequate information to allow others to comment. That is all. Missing information will surely be asked for. Photos will help too.
Allthunbs
allthunbs is offline
post #7 of 7 (permalink) Old 09-27-2010, 07:48 AM
harrysin's Avatar
First Name: Harry
A 1.5" dish cutter is the ultimate for what you want to do Gene.
Harry
harrysin is offline
New here & wondering... shopsmithtom General Routing 5 08-10-2009 07:48 PM
Wondering Blade DAUTTERGUY Wood Scrolling 8 12-01-2008 09:09 AM
just wondering... Denise16 Starting Off 0 11-28-2008 08:03 AM
just wondering Glenmore Lobby 0 09-13-2004 08:18 AM
