Router advice - Router Forums
post #1 of 4 (permalink) Old 09-29-2010, 11:50 PM Thread Starter
First Name: Albion
Default Router advice
A trip past the tool section at local Bunnings and a router stand to hold a Dremmel type tool came to notice. Can these be used in intricate routing work? Are they a viable unit for detail work?. Have they enough grunt to work at all cutting into a hard wood?.
Can you get small bits for them and I wonder what size shaft they would be. I 'm sorry if these questions seem silly but being unfamiliar with them I'm intrigued.
Thanks, Albion
albion is offline
post #2 of 4 (permalink) Old 09-30-2010, 02:05 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Albion
1/8" and 3mm shank bits are available. Dolls house makers use them for miniature work.
Proxxon do something similar. The Dremel is probably 1/8" and the Proxxon 3mm.
HTH
Peter
istracpsboss is offline
post #3 of 4 (permalink) Old 10-01-2010, 04:09 AM Thread Starter
First Name: Albion
Thanks for your reply Peter.
I do have a small Ryobi Hobby Tool CRT150K rated @ 130w.
Its got a flex cable option and some small abrasive stones.
I have used this with a small drill bit but its got no grunt and I would never of thought of a router type use for it...... Never to old to learn something each day mate.
Thanks and regards Albion.
albion is offline
post #4 of 4 (permalink) Old 10-10-2010, 02:25 AM
Country: South Africa
First Name: Jeremy
Albion
Before i got my cnc machine i used to use my dremel for intricate routing work that i did on necks of my guitars, so you can use them for routing work with a special router base that you can buy, but they are only designed for light work not to be confused with say a makita 1800watt machine.
jeremy budgen is offline
I think my old router nearly killed me! peacefrog General Routing 23 01-26-2014 11:36 AM
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
Router buying advice welcomed. Joeofalltrades General Routing 12 07-07-2008 10:58 PM
