Glue on Bessey clamps - Router Forums
post #1 of 11 (permalink) Old 10-07-2010, 05:20 PM Thread Starter
First Name: Kelly
Default Glue on Bessey clamps
I got glue on some of my metal woodclamps. Bad. Best way to get off?
Kelly Rittgers
Kelly Rittgers is offline
post #2 of 11 (permalink) Old 10-07-2010, 06:07 PM
allthunbs's Avatar
First Name: Ron
Kelly Rittgers
Most glues don't stick well to metal. What kind of glue? I'd just use a finger nail or a kitchen plastic scrub pad with goofoff or goobegone or something similar.
Allthunbs
allthunbs is offline
post #3 of 11 (permalink) Old 10-07-2010, 11:33 PM
BigJimAK's Avatar
Kelly,
When I got some titebond glue in the "teeth" of my K-bodys I used a razor blade on the body of the bar near the "teeth", got under the glue and it peeled back off the teeth.
BigJimAK is offline
post #4 of 11 (permalink) Old 10-08-2010, 08:36 AM
First Name: Danny
I had that issue before, now I use wax paper to wrap around the metal shaft of my clamps if I think the glue is going to get on them; it also protects against the black staining to the wood that happens when the metal touches the glue and wood.
jd99 is offline
post #5 of 11 (permalink) Old 10-08-2010, 08:58 AM
TwoSkies57's Avatar
I keep an OLD nasty, worthless 1/8" chisel on hand, just for this purpose. Titebond just loves to stick to bessey rails. *L*. I'll keep a fair at best edge on the chisel. Provides a bit of heft, yet easy to use and does a good job of bringing up the glue....a butter knife with abit of an edge on it would work just as well....
Skipper the Penguin
TwoSkies57 is offline
post #6 of 11 (permalink) Old 10-08-2010, 03:30 PM Thread Starter
First Name: Kelly
I think once I get them cleaned up I might spray TopCote on then.
KR
post #7 of 11 (permalink) Old 10-08-2010, 03:36 PM
RJM60's Avatar
First Name: Robert
I just don't get glue on my clamps ... or wipe it off right away ...
The single biggest problem in communication is the illusion that it has taken place.
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #8 of 11 (permalink) Old 10-08-2010, 10:41 PM Thread Starter
First Name: Kelly
I am going to not repeat this. What a hassle.
KR
post #9 of 11 (permalink) Old 10-09-2010, 02:06 AM
Kelly Rittgers
Hi Kelly - I assume you got a bunch on there or you wouldn't be asking. You didn't say what kind of glue so I am going to assume water based wood glue, ie. Titebond or similar. The Franklin website says that hot water will soften their Titebond products. Urethane based, about all you can do is scrape from what I have been able to find.
John Schaben
jschaben is offline
post #10 of 11 (permalink) Old 10-09-2010, 07:53 AM
TwoSkies57's Avatar
KR
Hmmmmmmmmmmmm says I...
a protective barrier between the clamp and the glue? Something like topcoat..as mentioned, paste wax, wd40....interesting idea...might just have to do a lil spar-a-menting...
thanks Kelly..
Skipper the Penguin
Multi-Sided Glue Joint clamps tigerhellmaker Tools and Woodworking 4 03-12-2010 09:45 PM
Bessey edge clamps - is someone using them? MarcoBernardini Tools and Woodworking 6 02-16-2010 05:37 PM
Bessey vs. Jorgie Clamps BigJimAK Tools and Woodworking 2 07-19-2009 08:09 PM
Bessey K-body Clamps on Sale at Lee Valley x372sailor The Bargain Bin 3 05-01-2005 12:16 PM
