variable speed routers - Router Forums
post #1 of 5 (permalink) Old 10-08-2010, 07:24 AM Thread Starter
Log
Default variable speed routers
I just joined your forum, thus a first post. I read some questions about VS routers. I have been routing signs for awhile and use a relatively inexpensive, VS router from Sears, i.e. a Craftsman. I don't like the plunge routers; their springs are too stiff. With a little practice you can attain the same results as a plunger router.
Looking forward to more discussions.
Log
Log is offline
post #2 of 5 (permalink) Old 10-08-2010, 07:50 AM
kp91's Avatar
First Name: Doug
John,
Welcome to the forum!
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 5 (permalink) Old 10-09-2010, 04:03 AM
xplorx4's Avatar
First Name: Jerry
Greetings Johnand welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 5 (permalink) Old 10-09-2010, 05:31 AM
allthunbs's Avatar
First Name: Ron
Log
Hi John:
You have just learned the first lesson of routers. It's what works for you that counts.
I've seen some sign makers machines and their modifications make it difficult to determine where the router is -- added light bulbs, vacuum hoses, oversized handles etc.
You might try looking at the OakPark 7" square baseplate modified with a large centre hole. Gives you a large, stable, square starting point.
Allthunbs
allthunbs is offline
post #5 of 5 (permalink) Old 10-09-2010, 09:06 AM
H John
You can rework the springs in most plunge routers so you can plunge it down with one finger..
But I will agree they set most of them up for King Kong just like the shaft lock pin on most of them but think they are King Kong and break the casting off ,most forget you don't need to jump on the wrench to get the router bit to stay in place..
So to say it's not in stone you can change it to fit your needs..
Variable Speed vs. Fixed Speed Phillip K General Routing 26 10-23-2013 10:38 AM
Bypassing Craftsman variable speed control emptyjay General Routing 13 02-14-2011 04:10 PM
Router Bit Sizes And Variable Speed Settings mack. Router Bits - Types and Usage 4 02-18-2010 11:33 PM
Variable speed routers MichaelT General Routing 10 02-24-2009 12:46 PM
How do you tell a router's speed??? allthunbs Table-mounted Routing 11 07-07-2008 03:08 PM
