Porter Cable 892-are they good - Router Forums
post #1 of 4 (permalink) Old 10-08-2010, 03:32 PM Thread Starter
First Name: Kelly
Default Porter Cable 892-are they good
I read that the Porter Cable 892 has play in the up and down raising mechanism. Does anyone know if this is true? Other issues?
Seems like a good brand and in theory would be good for a router table lift.
KR
Kelly Rittgers is offline
post #2 of 4 (permalink) Old 10-08-2010, 03:51 PM
kp91's Avatar
First Name: Doug
Kelly,
I have 3 890 series routers, two fixed bases and two plunge bases. The fixed base routers do have some backlash in the adjustment rack, but it hasn't ever been an issue for me. Once the motor clamp is tight, the thing isn't going anywhere. What I have noticed is that the adjustment knob will move a touch when the router is running due to vibration, and if you undo the clamp it may move a bit. If you put a little tension on the knob before you undo the clamp, this goes away.
I think they're great routers, I love being able to swap out the motors between the bases instead of changing bits, and the motors are great. The spindle lock feature is a little bit of a pain, I prefer to use 2 wrenches.
I rarely use the above the table height adjustment, because out of habit and bad eyesight I still tend to get down on one knee and get a good close look at the bit height in relation to a setup block or scale.
The one thing I think the routers suffer from is they can be a little top heavy when in the plunge base. If you don't set the motor down into the clamp as far as it can go, and chuck up the bit as deep as you're able, they can feel a little 'tippy'. A bigger base plate solves a lot of that.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 4 (permalink) Old 10-09-2010, 02:25 AM
BigJimAK's Avatar
Great info, Doug!
BigJimAK is offline
post #4 of 4 (permalink) Old 10-09-2010, 01:15 PM
First Name: Chuck
I am new to using a router and I have the 890 with the plunge and what I refer to as the standard fitting. I have used it now a few times with the plunge on, an edge guide and last night I used it on my inca table with the fence.
So far I am satisfied with it. I have had a bit of trouble understanding the manual and how to adjust things but this may be more my problem than what someone who as used a router before would have.
I am looking for another to be able to leave it on my table. I also am thinking of a larger PC router for the table but after doing the routing on the table last night the router had all the power I needed but I was not cutting hardwood which might make a difference.
Chuck
Midnight Shadow is offline
For Sale: Porter Cable Router Height-Adjuster for 891 &892 routers muske Woodworking Classifieds 3 06-11-2009 02:02 AM
Porter Cable 690 PeterLowes General Routing 3 01-20-2009 12:57 PM
porter cable router bits delroy33 Tools and Woodworking 1 10-14-2004 05:37 PM
