Using a palm router - Router Forums
post #1 of 13 (permalink) Old 10-09-2010, 02:16 PM Thread Starter
First Name: Robert
Default Using a palm router
I've always used a plunge router and now have purchased a Bosch Colt 1.0 hp palm router as well. I want to use the new router to cut away background on my wood carvings.
What is the safest way to do this, and what is the best bit to use? I want to be able to move the router back and forth horizontally and vertically.
Thanks for any help.
roberttw is offline
post #2 of 13 (permalink) Old 10-11-2010, 11:28 AM
Neil Tsubota's Avatar
First Name: Neil
Default Laminate Trim Router <=> Palm Router....
Use the tool for the "intended" purpose.
It is my understanding that a Bosch Colt 1.0 hp is intended to "trim" laminate, (or formica counter tops). Read the instructions and most "quality" wood working tools will send you the Instruction Manual in PDF format for little or no costs. This is cheaper than dealing with a "personal-injury-lawyer".
Why are there more lawyers in California, than ANY other statein the US ?
Neil
Neil Tsubota is offline
post #3 of 13 (permalink) Old 10-11-2010, 11:43 AM
Hi Robert
The colt is a great tool and not just for trimming , see my uploads for many pictures of the Colt...you will want to get a base for your Colt for a bigger foot print and two knobs to hold on to for more control on your wood carvings..
It will turn just about any router bit with a 1/4" shank.
Amazon.com: Woodhaven 8320 Bosch Colt PR20 Bushing Plate: Home Improvement
http://www.routerforums.com/general-...er-unsafe.html
http://www.routerforums.com/attachme...e-100_1805.jpg
post #4 of 13 (permalink) Old 10-11-2010, 11:51 AM
That's because the voters in New York and California decided to swap lawyers and New York won. That vote raised the IQs of both states.
bill strop is offline
post #5 of 13 (permalink) Old 10-11-2010, 11:52 AM
Hi Robert, welcome to the forum
I assume by "carvings" you are doing 3 dimensional stuff like statuetes or something like that?
I have the Trend T-4, also a laminate trimmer, and the manual has me removing it from the base for freehand carving. Doubt I will ever use it that way, sounds a bit risky to me. Wouldn't be any way I can see of controlling depth of cut other than some severe concentration. Trend is considerably larger than the Colt is though so that may be the way to go, kinda like a Dremel on steroids.
As far as bits go, I would guess a small dish cutter or round nose would work. V-groove for finer detail work.
May help if you posted a pic or two of what you are planning. Picture worth a thousand words (does take about a million times the disc space though)
John Schaben
jschaben is offline
post #6 of 13 (permalink) Old 10-18-2010, 08:27 AM
First Name: Neil
Does a 1.0 HP Laminate Trim router produce a "kicK" when started ?
If so I would not like this unit....if it does.
post #7 of 13 (permalink) Old 10-18-2010, 11:00 AM
Hi Neil - All motors are going to produce some "kick", Isaac Newton thing. Question is how well is it controlled. I think most of the newer routers have a "soft start" feature which reduces the kick. My Trend T-4 produces a little kick but nothing that isn't managable and can be reduced further by having it on the lowest speed setting when powering up and then increasing the speed to where you want after it is running. The Trend has an almost ridiculously high speed anyway, like 32 - 34,000. I have yet to run it over half speed of 24,000.
John Schaben
jschaben is offline
post #8 of 13 (permalink) Old 10-18-2010, 01:20 PM
MikeMa's Avatar
I believe the Colt, like other Bosch routers has a soft start, which dramatically reduces the kick.
MikeMa is offline
post #9 of 13 (permalink) Old 10-18-2010, 03:01 PM
Phil P's Avatar
First Name: Phil
Do they have less road kill there as well?
Phil P is offline
post #10 of 13 (permalink) Old 10-18-2010, 03:25 PM Thread Starter
First Name: Robert
The kind of carving I'm working with is "relief" carving. The background I want to remove is all that wood from around the relief. I use carving chisels to carve the relief. To try to remove the background with carving tools is just too time consuming.
Thanks for the help so far. I'll post a picture later to try to demonstrate better.
roberttw is offline
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
