Problems with Hitachi M12V - Router Forums
post #1 of 2 (permalink) Old 10-09-2010, 06:32 PM Thread Starter
Default Problems with Hitachi M12V
Not sure if this is the right place or not but my Hitachi M12V router, which I have had for about 10 years and simply love, quit in the middle of a job. I thought I had blown a circuit breaker but alas this was not the case. I removed the motor cover and could not see anything obvious so replaced it and fired it up. To my amazement it started, but as soon as I started to cut it quit again. A day or two later I tried it again. It started but only ran about 15 seconds and the quit. Has anybody experienced this problem and how if so how did you correct it?
Than ks
Ayjay
Ayjay is offline
post #2 of 2 (permalink) Old 10-09-2010, 06:43 PM
Hi Ayjay
Did you have it in a router table ?,,if so the M12V was not made to be used upside down all the time ,take the switch out and blow out the saw dust, you can check it by passing the switch, if blowing out the switch didn't help you will need to replace..or use a router speed box device, a 20.oo item, it may be cheaper than replace the switch..if you can find one...
Router Speed Control
MLCS Router Speed Control and Billy Pedal Foot Switches
Than ks
Ayjay
Hitachi M12V and Bosch 1619EVS routers LBrandt Table-mounted Routing 4 10-29-2011 12:44 PM
1/4" Collet for Hitachi M12V RzzB General Routing 53 07-26-2011 10:32 AM
Setting the proper RPM on the Hitachi M12V jrs4464 General Routing 5 01-10-2007 09:34 PM
Hitachi M12V issue Warren White General Routing 4 03-23-2005 10:03 PM
hitachi m12v and spiral upcut bit routerman1969 Router Bits - Types and Usage 1 02-19-2005 05:08 AM
