grain cutting which direction - Router Forums
post #1 of 3 (permalink) Old 10-10-2010, 02:15 PM Thread Starter
First Name: david
Send a message via AIM to drainman
Arrow grain cutting which direction
get a piece of wood cut in the direction that i think is away from the grain finding long trails of wood not shavings and winding up with firewood because i am cutting to deep what the hell am i doing wrong doing it in stages a small bit at a time.First i cut the tongue this is were i get the long thick shavings.my wood is 3/4 thick and i am cutting 2 recess for the tongue using a 1/4 bit using a boch a500 in a router table.help and i haven't any idea what wood i am using could be pine not a red wood Lucky you can get any wood in Britain :
drainman is offline
post #2 of 3 (permalink) Old 10-10-2010, 04:59 PM
Hi, sounds like you may be using an upspiral bit. I usually get wound up strands of fiber when using one of those types of bits with pine. Upspiral will also be trying to pull itself up but haven't noticed it actually happening. Try a regular two flute straight bit.
John Schaben
jschaben is offline
post #3 of 3 (permalink) Old 10-10-2010, 06:17 PM
Hi david
It just may be the lumber or the way it was milled,,I have seen some heart wood from pine act like that if it's bit green that is...I would say try some other lumber and give it a go..or use a Good Sharp bit..pine will dull a bit it short order or to say fill up with pitch on the cutters..
Cutting boards for gifts.... gad5264 Project Plans and How To 16 08-17-2016 07:35 AM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
First Cutting Boards Soapdish Show N' Tell 3 02-03-2010 10:35 AM
Climbing, climb cutting TWheels Tools and Woodworking 9 08-27-2009 12:10 PM
New - Boxjoint Cutting feed direction Makavelli Table-mounted Routing 8 07-04-2006 03:49 PM
