router collets - Router Forums
post #1 of 6 (permalink) Old 12-02-2010, 03:54 PM Thread Starter
First Name: Phil
Thumbs down router collets
Hi there, I am new to routing and I have aquired an ancient ELU MOF 177 router. My problem is that it is fitted with a quarter inch collet and I would like to use half inch bits. Does anyone know where in the North of England I can get a replacement collet. Will a collet from another make fit?, if so does anyone know the part number.
cheers Phil
talula is offline
post #2 of 6 (permalink) Old 12-02-2010, 04:30 PM
LexB's Avatar
First Name: Lex
It doesn't work that way. A router with a quarter-inch collet only has the horsepower and torque to safely use quarter-inch shank router bits. Buy a half-inch router if you need larger bits. The larger router typically comes with a collet to let it use smaller bits because power isn't an issue with the larger routers.
LexB is offline
post #3 of 6 (permalink) Old 12-02-2010, 05:16 PM
Hi Phil
The Dewalt DW625 and the ELU MOF 177. Except for the chuck,
the parts for each are identical. Even the castings are the same.
It's a long shot but ask a mate, that has one so you can try the chuck on your 177, with luck it will fit..than you can one easy.
cheers Phil
post #4 of 6 (permalink) Old 12-02-2010, 06:13 PM
Cassandra's Avatar
First Name: Cassandra
http://www.trend-uk.com/en/UK/produc..._dw625ek_.html
Hi Phil:
Had a look for information on 1/2 inch collets for the ELU. They might still be available. Trend mentions the 1/4 inch, 8 mm and 1/2 inch collets. So, I would expect other suppliers might supply them. Bob's suggestion is worth a go.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #5 of 6 (permalink) Old 12-02-2010, 07:31 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Phil
The Dewalt ones should be the same, as Dewalt took over Elu and the 177 is now the Dewalt 625 series.
Dewalt collets items - Get great deals on Business, Office Industrial, Home Garden items on eBay UK!
istracpsboss is offline
post #6 of 6 (permalink) Old 12-04-2010, 04:14 PM Thread Starter
First Name: Phil
Hi there all, thanks for the quick replies and advice, I am goig to urchase one of the suggested Dewalt ones off the dreaded Evilbay.
regards Phil
talula is offline
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
So you want to buy a router table... BobandRick Table-mounted Routing 39 08-30-2010 06:23 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 08:01 AM
chicago router reducer collets douger1 Tools and Woodworking 1 03-29-2009 04:25 PM
