Router sub base removal - Router Forums
post #1 of 6 (permalink) Old 12-03-2010, 01:13 PM Thread Starter
First Name: TERRY
Default Router sub base removal
I have a ryobi router /table combo i bought at home depot.the instuctions don't tell me to leave or remove plastic sub base plate.the router mounts fine with it in place but concerned about breaking something if i"m wrong.just started learning about routers and i want to be sure.
LOKI is offline
post #2 of 6 (permalink) Old 12-03-2010, 01:21 PM
dutchman 46's Avatar
First Name: Howard
I have the Ryobi, and I would remove it. It will give You just a little more height to the bit. It may also hold the router a bit more solid., just My opinion
John 3:16
dutchman 46 is offline
post #3 of 6 (permalink) Old 12-03-2010, 02:27 PM
xplorx4's Avatar
First Name: Jerry
Greetings Terry and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Remove it.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 6 (permalink) Old 12-03-2010, 04:33 PM
The Warthog's Avatar
First Name: Roger
I take it you got the one with the router included. Did you have a look at the assembled one in the store? I would take the plastic base off it anyway, as I do with my Mastercraft router on my Ryobi table. You can also make auxiliary bases for different purposes, for instance to give yourself a straight edge, or to make a trammel (circle guide) The plastic face is for handheld routing.
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
post #5 of 6 (permalink) Old 12-03-2010, 06:17 PM
Hi Terry,
Welcome to the forum
Sydney, Australia
jw2170 is offline
post #6 of 6 (permalink) Old 12-06-2010, 05:16 AM
First Name: Howard
I don't think so, but every router I have seen with the plastic base plate come off with the help of removing 3, or4 screws. Lay them aside with the plate. I have seen one small router with a sticky sheet plastic. Those are the only ones that need to stay!
John 3:16
Bosch 1617 router base problem bill kay General Routing 35 05-30-2016 08:39 AM
Model 320.17542 and table routing 46_trap Table-mounted Routing 44 10-16-2011 01:40 PM
Router plate removal sshorter General Routing 8 11-22-2010 08:32 AM
Mounting Router Base to Table Plate ccmnova Table-mounted Routing 5 12-02-2009 07:10 PM
Wanted: Wanted--fixed router base for craftsman 315.175311 kirkneal Woodworking Classifieds 3 11-30-2009 07:18 AM
