hinge routing - Router Forums
post #1 of 12 (permalink) Old 12-03-2010, 03:22 PM Thread Starter
First Name: Chris
Default hinge routing
Hello all,
spending more time at home now so in an attempt to make my self useful I am turning towards doing most house maintenance. (dangerous but fun).
My first test is to find out how the rebates are achieved for kitchen cabinet concealed hinges. Saw a thread on this but the photos don't show the method.
Very useful site for people like me but will be some time (a long time) before I can advise anybody on routing
ukdiyer is offline
post #2 of 12 (permalink) Old 12-03-2010, 03:24 PM
xplorx4's Avatar
First Name: Jerry
Greetings Chris and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 12 (permalink) Old 12-03-2010, 07:19 PM
Hi Chris,
Welcome to the forum
Sydney, Australia
jw2170 is offline
post #4 of 12 (permalink) Old 12-03-2010, 07:36 PM
Hi Chris
If you are talking about the type below, very easy with the right jig or with a router..
Rockler - Search Results for 'concealed hinges'
http://www.rockler.com/product.cfm?p...%20hinge%20jig
http://www.rockler.com/product.cfm?p...ealed%20hinges
If you use the 1.750 hole = (1.375" finish size ) router bit hole way in your plastic template jig you will need to use the bit below..they just need to go 7/16" deep the norm.
http://cgi.ebay.com/1-pc-1-2-SH-Mort...item20b51da158
See How-To-Do It Video on the same web page..
The high end jig
http://www.sommerfeldtools.com/Somme...oductinfo/SHB/
http://www.sommerfeldtools.com/somme...ans/ezbore.pdf
Originally Posted by ukdiyer View Post
Hello all,
post #5 of 12 (permalink) Old 12-03-2010, 07:38 PM
dutchman 46's Avatar
First Name: Howard
Hello Chris ! Welcome to the Router Forum. Glad to have You join. It is great that You can just come here and learn. That's what We are about. This is a great hobby, or a job, it's fon to learn all You can. You can ask guestions if Your not sure about something It is't neccessary to bring any thing but questions. Then when it is answered, We all learn.
John 3:16
dutchman 46 is offline
post #6 of 12 (permalink) Old 12-04-2010, 09:51 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Chris
Following up on Bob's suggestion, as you won't be able to get Rockler stuff in the UK, the jig itself is easy enough to make. I made mine with a sample rectangle of Lexan that I scrounged from a shop that sold the stuff.
You can fix a fence to it with csk screws. You can then trace the position of the big hole and screw holes on to it.
Now then,there are a couple of possible sizes for the main hole.
If you use a short bit with a top bearing on it, the hole can be the same size as the one you want to cut out for the hinge.
However, Rockler suggest doing it with a guide bush, which gives you more flexibility on bit length. If you do it their way, the main hole will need to be larger than the one you intend to cut for the hinge as you need to allow for the bit being within the guide bush and not bearing directly on the jig. The size will thus depend on the guide bushes and bit sizes you have available.
I liked their idea of using the screw hole guides to clamp the jig in place.
On the other hand, and I know we are a router forum, you'd be much quicker getting hold of the right sized Forstner bit and doing them in the drill press.
Cheers
Peter
istracpsboss is offline
post #7 of 12 (permalink) Old 12-04-2010, 10:16 AM
Hi Chris
Peter is right on I also made two of them with some plastic stock very easy job and by using a pattern bit no brass guide in needed, I also made a jig for the drill press it's a bit of a tank of a jig but works well almost no setup just slide the door in place and drill the holes out...no clamping needed..I have not posted that jig because it's tank..but if you want to see it just ask and I will.
1 pc 1/2"SH 2" Blade Top Bearing Flush Trim Router Bit - eBay (item 130459433535 end time Dec-04-10 11:33:10 PST)
Router Forums - View Single Post - Concealed Hinge Jig
Here's a snapshot or two for the jig,made to work on a drill press.
It's not the best but it sure beats paying 200.oo bucks for one.
Amazon.com: MEASURE PRO 35MM HINGE MOUNT KIT: Home Improvement
Amazon.com: Drilling Gauge/Inserta: Home Improvement
Note,,,not needed if you use the face frame way to hold/mount your doors. ▼
Amazon.com: Rockler JIG IT Mounting Plate Template B: Home Improvement
see below
post #8 of 12 (permalink) Old 12-07-2010, 07:06 PM Thread Starter
First Name: Chris
Wow,
so much information and all useful. This is obviously a 'live' forum. Many thanks for the responses and advice. I have already learned how not to kill myself by avoiding a Forstner bit/router combination! (and yes, I probably would have tried that).
I have found an outlet in UK selling Forstnet bits, have yet to assess quality of product but will set up a drill jig and use a 35mm dia. bit.
many thanks
Chris Clark
(not sure where I fill in details but will get around to this)
ukdiyer is offline
post #9 of 12 (permalink) Old 12-13-2010, 05:44 AM
Country: Croatia
First Name: Peter
Wow,
many thanks
Chris Clark
Hi Chris
Try Search results for "forstner " from Rutlands.co.uk
Cheers
Peter
post #10 of 12 (permalink) Old 12-13-2010, 09:14 AM
First Name: Howard
Glad that You are enjoying the forum! This is as real as a slap on the hand! I am sitting in Holland Michigan, hoping that the wind and snow stay away
John 3:16
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 10:33 AM
A routing tutorial for beginners Part Four harrysin Guide Bushings and Templates 23 04-21-2013 10:31 AM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 05:24 AM
template routing woodyone General Routing 4 11-20-2008 02:53 PM
Butler Table Hinge joekuhn Jigs and Fixtures 3 10-05-2008 09:26 AM
